Vic Wasteland Thread
R31Nismoid
Out of 300 people, only one couple gave me a non cash present. It was a photo frame..... uwotm8
I bet out of the 300 people you'll remember the photoframe couple the most lol
People invite way too many f**king people to weddings is the problem, they're self indulgent bullshit at its finest.
They are the selfie of events.
Too expensive to invite heaps of people, close family and friends will be enough for me
This!
  • Like 3
We used the engagement party as a way to weed out ppl
As we did it at Amy folks home we could invite lots and stlill keep it chea
If ppl did not rsvp or worse rsvp they were coming and then not turn up with out contacting they were off the wedding invite list
Got numbers down so quick was great
  • Like 4
Pop Quiz:
Tony - What did I get you for your wedding gift?
Everyone Else - What should I have gotten him that would have been the most perfect present ever and made Lynnie hate me for life?
Ric gonna be remembered for a long time and that vase will shine up instead of being spent on a holiday or the next iPhone.
Hopefully! Will check if it's visible in their home when they invite me around for dinner
Pop Quiz:
is the answer a stripper?
Birds, I need to hire you for breakfast dem eggs looked maaad.
also, dat vl @ 1 min, & 5:45 running an easy 9 moh you needa get one - 800hp min
Edited by UNR33L
Yeh I agree but is what it is, gifts are fine but getting shit u don't want blows for all we know rics vase is an annoyance they have to keep and pull out in the event he comes over.
cash has been the norm for certain cultures for ages
not with the brakes planning
with 295's?
it all good going to have some fun with the car this year.
start lining up some parts to fix the cosmetic issues and make go faster at same time.
good time to be alive.
I got 275 on 10.5" under there, and that was with a fairly wide offset (+22) I flared the guards enough to easily get 295 under there. If you want to be safe, get a higher offset. If I remember correctly there was plenty of strut clearance
what you running front?
that's my big concern, rear I ahve to do something wild anyhow as the guard is fked
front I have some options...
I had 9.5" +12
I can't remember the tyre size though. Fronts had heaps of room. My offsets were too low, should've gone a little higher.
Hollandaise or the deconstructed with bacon bits and garlic bread?
I demand further clarification regarding this hollandaise of which you speak.
Didst thou purchase said hollandaise from ye olde supermarket like a common peasant or didst thou appease thine hollandaise gods and maketh same?
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
