Went to Kobe Jones for 8 courses last night. Was good... Though not up to scratch with other restaurants of the same caliber. Give me shoya any day.
And something about the open-air lesbian Australia day party on the other side of the glass pump in Shit house music for the 3 hours we were there spoiled it a bit.
All the Ellen Degeneres clones...
Nothing worse than having a nice meal spoiled by others.
When we went to Rockpool everything was great until after an hour a table was seated next to us... 6 guys, all in Addidas trakkies and runners, peaked caps on inside the restaurant etc.
Of course they are loud as hell and evtentually lean over to us and explain "this is what happens when Wogs have too much money."
They then proceeded to demand all sorts of meals be made fat free and started going over the food on our table to see what it was etc.
After complaining multiple times about the fat content of the marbled steaks the stupid f**ks then order sides of mac & cheese and proceeded to take turns in 2's and 3's to go for ciggies to the point where at no time after ordering were they all in the restaurant at once, which of course led to food needing to be reheated multiple times followed by complaints about how long this took.
We ended up skipping desert/aperitif's and going to the super club instead to get away from the douchelords.
I nearly drive to the north to hit Mohsen the next day.
10931049_10205914880694107_8233712779688
I subscribe to the weekly MTF happened to Moh mail list...
seriously wtf.
crusing along on the freeway, f**king audi toureg mirror to the front bar.
they did a runner too... and the cops actually got me their details.. within 2 days.
i think the chick constable thought i was cute.
on another note.
BIIGGGGGG THINGS TO COME.
scotty and platts, thank f**k i visited
or my strategy worked. bring a non arab mate.
mate i was chillin, watching jim jeffries and smoking some sheesha
should have come.
seriously wtf.
on another note.
They prob didnt even notice?
And if they did a runner, how did you let em get away? You got a rb26 m8
Hey guys need help iam mssong a pipe from intercooler that goes to from intercooler to turbo side
Can some one help me out here ?
Full kit is bit expensive and i already have everything but just one pipe gone missing
Or can someone suggest me a cheaper way just to get a pipe
It looks sort of 90degree angle pipe
Edited by aneesr34
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
