There is a market, but I'd be worried it will die soon.
R35 GTR price keeps dropping and 34R's are only getting older.
Spend $60k and own it for 2 years as a weekender, drive it a handful of times and all it for $30k does not sound appealing to me. I might buy one after the drop.
yeah that is true 35s are under 100k but I think they are a different proposition got very high maintenance costs .. Not that a 34 won't cost money but the 35s got a lot of stuff that can go wrong and cost big $$$
Eh maybe I'll try find a 180sx to trash around a track in lol
Fark that would be a fun car
And Narva headlights on the front :thumbsup:
I'm a fanboy of these:
http://carsales.mobi/cars/details/1964-Sunbeam-Alpine-GT-Series-IV/SSE-AD-3191987
But getting rarer and rarer to find. Would probably do a half assed restoration. Bolt on flares, big wheels, efi V8. All the oldies would be disgusted
Is cool, needs more Renault less Sunbeam doe :P
4K, pointless at this stage
3D, pointless since they were launched like 5 years back
65"... unless you've got a big room, the 480p/720p/1080p content you'll be playing on it will not be as sharp as it should be.
Would still bang, but not for that price
For the difference in price, I'd be going for this... then upgrading in a few years to a good TV once 4K porn is actually available
https://www.kogan.com/au/buy/kogan-50-led-tv-full-hd-za/
Yep.. and with aussie internet speeds the way they are going to be a long time before 4k is viable (depends on area I guess)
Our free to air only just got 1080i on a few channels heh.
Only reason you'd get a 4k TV is if you had a massive collection of stored 4k blurays or something
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
