I lol at these people who think their car is some flux capacitor NASA rocket shrouded in mystery; it's mostly R35 owners guilty of doing this. If I owned an R35 I'd still change the oil myself.
This. Only time I would ever pay someone is for logbook/warranty reaaons
So a few months ago I'm guessing October...I stopped at a park on Sydney Rd Cambelfield to use their ammenities...I noticed a dark green VR there, windows all covered up, obviously some homeless person living in their car..
So I went their again today...same car still there, windows covered up and its running with the AC on...
Dont you think somebody would've said something buy now..lol
Is part of your Job position description to be deployed part time at local GTR meets?
Have I.missed something ?
Just saw a ft86 zoom off at lights....sounded ghey, and where is the boxer burble. :ermm:
Edited by ARTZ
Soooooo I bumped into an Andrew Bolt "article"
It was just a massive sook about the ABC trying to destroy Abbott and the LNP. He went on to cry incessantly about ABC shows putting on more left wing guests than right and also speaking over conservatives... and that would be fine, as there is definitely a left wing agenda with the ABC at times...
BUT
I also watched an episode of "the Bolt Report" and lets just say he's not exactly in a position to complain about bench stacking or talking over people with opposing political views lol.
It's "womans day" quality journalism thinly disguised as political commentary.
By that token I also read a Waleed Aly "article" that was just as whingy, and equally devoid of merit...
How come you didn't say something?
fyi for those that care,
club permit scheme is now officially f**ked.
RWC and VASS cert for modifications only way to get one now
Still worth it if you only drive on weekends and car is 25 years old
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
