Yeah I've got two new O2 sensors. Car has always been a pig to drive until it got to about 1/5th on the water temp gauge then all of a sudden it goes into a different map and drives as if its come onto boost. Did it on standard ecu and now Nistune. So I'm a little concerned it might be the very expensive ignitor as most other things have been changed. Still makes a lot of power though :\ Realistically haven't got much different fuel economy from Tuned E85 to stock ECU on 98/100. So somethings definitely causing fuel to get raped in the first 5 minutes of driving more than it should..
Edit: To clarify I'm managing about 250kms daily driving, probably could get more but I'm not keen on finding out how fast the last bit of E85 disappears. This seems pretty low to me considering I don't thrash it at all.
Coolant temp sensor all good? What temperature range plugs are you running? Stock coils?
Well I got a second hand one with the car when I bought it so I'm gonna assume he changed it for a new one (coolant temp sensor).
New BKR6E gapped to .08
Splitfire coilpacks
New coilpack loom
AFMs just changed for another set
O2s new
Racepace use BKR plugs over BCPR or that your choice?
You might be right, truth be told it was just what came off the top of my head. Now I'm not sure which one. Regardless though whichever one it is its worked on countless cars so it SHOULD be fine in mine, it's the right plug for RB and E85 anyway..
Yeah just did some looking up on that and you're right. Shouldn't be the problem really and I'm pretty sure its BKR6E that we use not BCPR6E.
Looks like I'm going to have to just keep throwing parts at it, hard one to diagnose on the dyno as you have to leave it on overnight, check it in the morning on a cold engine and you have to know what sensors SHOULD be doing what at what temperature, and hope that you notice one of them change suddenly and more drastically. Even though all the other ones will change at the same time too.
can go past dat 3rd gear overtake move @ 80
It is good and that's what I do with my rolling drags, dropping to 3rd at 80 is actually my favourite move! Closely followed by 2nd at 50 when approaching lights and they turn from red to green...
lol my friend used to drop to second at 80
You're gonna hate -9s on a 2.6 then! Had some kid try to be hektik in his stock GTST giving those little pulls next to me today at 80kmh. I geared down to 3rd and put the foot down, I basically just coasted away making small amounts of boost, it wasn't very impressive I must admit. That's with -7s as well!
they both work, it's just the BCP have a ~2mm longer electrode and contact slightly better
BKR wouldn't cause the issues, I was just curious
For this reason I use BCP...my coilpack springs are a bit short and I had random non firing cylinder issues
How much power you running?
May have to swap for -5s, but I love response and will take it over outright power any day
Also winning is winning haha
Speaking of, very easily dispatched of an Evo 8 off the line today...where he really should have got me...instead he got bogged down off the line and if that happens it's all over for a 2 litre turbo AWD
Do crashes necessitate a write off or can be a minor incident?
Thefts:
Ric
Borci
Birds
Tony
Alvin
Crashes:
Hamish's m8
Do bikes count? had 2 stolen :(
Forgot I wrote off a 33 when I was 18 as well lol.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
