Don't know if I could do a lan though it's 2015 man! interwebs!
There's still something very entertaining about all being in the same room, talking shit and having fun...
Most of the time we're playing on a public TF2 server anyway, and deliberately trolling people as a group :P
The new girl at work showed up today in her new car (after having her old car t-boned / written off on the way to her first day here about a month ago). Yesterday she was talking up her great deal / 12 month warranty / etc...
Nek Minit... 2001 Astra, haha... Yeah good luck with that
lol wtf? why would you talk up a car when everyone at the workplace is eventually going to see it
TF2 and Dota 2 is fun times, don't want to sound like a typical wastelander, but I'm the best.
Because she legitimately thinks its a good car... probably because it's got shiny paint... aka, the used car dealer detailed it and peeling paint will show up again after 2 weeks :P
Dota I'm crap at... TF2 I'll give you a run for your money...
She any good?
Yes
Lol I'm actually at my cousins work shop servicing my gfs 2001 astra.
For the first time in car history, chucked obd2 tool on it and no error codes
Also, none of this gay mainstream LAN games stuff.
My share of the list.
Do crashes necessitate a write off or can be a minor incident?
Thefts:
Ric
Borci
Birds
Tony
Alvin
Huy
Crashes:
Hamish's m8
better question, who the f**k faxes anything these days?
I havn;t faxed something since this guy was probably born
Was asked to write something to fax to another place today.... emailed instead. Maybe that's why she didn't reply.
If we play cs I'll probs rage quit after 2 rounds
Also have party games that don't need LAN. Only 1 pc and all players need smart phone or tablet. Pictionary using touch screens is entertaining . Especially with cock n balls
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
