anyone got any moving boxes sat around?
I gave all mine to a friend moving out already.
But go to any retail and ask for their boxes when they work stock. Could be morning or night, just got to ask when they unpack their stock.
i just pay the $110 and stay at the Benalla caravan park. much better/easier and still get to sleep in own bed saturday night
also, f**k australian games classification. have to pirate Hotline Miami 2 (as per instructions from developer) because the 8-bit looking game didnt pass R18+ classification.
for anyone else keen: https://kickass.to/hotline-miami-2-wrong-number-t10331590.html#main
like top of the town in benalla, they ahve a side gate that sis locked at night so you can drive in with trailer and drive straight out:
http://www.topofthetown.net.au/guestrooms.html
http://www.buzzfeed.com/markdistefano/head-desk-boy?bffb&utm_term=4ldqphp#.uiBprZa1v8
/subtle labor don't need a treasurer to score points to know about heading in the right direction :P
I can just see Abbott telling the 5 year olds about how he stopped the boats and his frustrations in not being abke to pass the medicare rebate and having absolutely no idea they aren't interested
I'll think of a few labor ones just to make it a democratic joke
Rudd would apologise profusely to the token aboriginal student (actually an Indian kid) on behalf of the rest of the class, hoping they'll put up some sort of Rudd plaque in their newly constructed billion dollar hall
Peter Garrett would inadvertently burn the school down and blame it on the kids (how do we sleep while our beds are burning?)
Gillard would take the lunch money from the kids who actually brought money to school and tell them their parents can obviously afford it
Chris Bowen would ask a kid for help with his Maths homework
    • Just get rid of the orignal low impedance injectors, replace with modern high impedance injectors, and you won't need the resistors. Wire direct, as per any other engine.
    • Tao, we're not talking about the ECU boost ref. We're talking about the wastegate signal source.
    • Flapping up and down is a consequence of the varying pull on the belt. When the engine speed is suddenly increased, the tension in the belt increases too. When that engine accel changes to decel, the tension is reduced and turns up as a little extra length of beltes between the pulling and dragging pulleys. That extra length flaps up, then down. There's all sorts of other harmonic stuff going on too.
    • hello ladies and gentlemen so i’ve swapped a rb26dett into my r33 gtst and ive come across many speed bumps but its nearly over what im having issues with is the injector resistor box that are normally on the RB26 fuse box but im still using my rb25 fuse box and as a result my injectors aren’t getting power and is the last thing i need to figure out so the car can start. can anyone help me out on where i can find a wiring diagram for the rb26 harness to see where the injectors are supposed to receive power
    • The boost pressure at the compressor cover will be higher than at inlet manifold. lets say, trying to hold 20 psi flat at 7000 RPM. If your wastegate opens at 20 psi measured at the compressor cover, the engine may only be seeing 16 psi. Your base pressure reading at engine would be 20psi by 4K and 16psi by 7K while your MAP at compressor housing still reads 20psi at 7K. For this reason your ECU's MAP source is never on the compressor cover. This difference isn't a major concern if you're using an electronic boost controller (EBC).
