Brought it home yesterday, pulls like a freight train... midrange definitely changes a car way more than top end power does. before it was breaking traction (265 ad08r) at the top of 2nd and chirping 3rd, now it's breaking traction for most of 2nd and if I change into 3rd hard it'll keep it going. Need to get used to that...
You need to work on your suspension setup more.
My car had more midrange / power and didn't break traction at all in second without a clutch kick,
and that was on worse tyres aswell (on both NT05 & KU36) and not the most advanced setup under the sun
(greddy coils 6/8 low and on hardest setting, pineapples, castor bushes, swaybars and 1.5 way diff)
The only time it broke traction in second was 20+ psi on e85 (325rwkw) but on low boost ~ 15psi (300rwkw) or 98 it was just plant foot and forget about it in all but 1st gear
Cricketer Adam Gilchrist just cut in line to get on the plane from Perth > Mel.
Disrespecting my platinum status.
Can anyone enlighten me as to why he in Perth and then travelling to melb?
because who gives a f**k?
variability.
I don't know how dyno dynamics calculates engine torque...obviously some sort of correction for it; maybe it's open to
Now, folks, I don’t wanna alarm ya, but scientists say ninety percent of Australia's dyno's… are reading torque crooked.
Yep, it’s true. And I hear you asking: “Well, who’s gonna straighten out all these overtorqued abominations?” Your friends? A neighbor? Those fat cats at Washington? Good luck. Hey, you know, maybe no one’ll notice! Maybe the problem with ju-u-u-st fix itself.
You sound like you’re ready to become your own boss in the exciting world of Hub Dyno'ing!
Yes, for a minimal franchise fee, you’ll receive a pair of Hubbing gloves, a cannister of hub lubricant and a booklet of the most commonly asked questions you will hear, including: “Who are you?” and “What are you doing here?”
I have over 300kw/4WD and still can't match your times. Practice and suspension set up plays a big part in that I think. I struggle big time with corner speed.
I am hoping to shave 10-15 seconds a lap with my new MCA reds in the Evo, but bumping the boost 10psi only got me 1/2 a second at PI. I totally agree with this.
Pretty normal for E85 to be unresponsive and choke up with a cold engine. Spark plug heat range prolly a factor too.
Once started I can use the throttle immediately, but I always roll it on slow...if I stab too quickly idle drops. It also need a bit more revs when cold and letting the clutch out for take off or it will die in the ass. After a couple mins of driving or idling it runs fine and dandy with dat super response, but I've learnt how to drive it so that I can start it and start driving basically straight away.
As for actually starting, that depends how pure the E85 is in the tank. While there's still some petrol in there, starts will be easy. With pure E85 and on cold mornings mine can take 2-3 cranks to turn over. Helps to add a minuscule amount of throttle as I turn the key. Warmer weather and it's first crank good to go.
You need more cold start enrichment and cranking enrichment.
cos you drive like a hoon not a racing driver lolololol
this. 30% extra fuel on start up.
FFS how long do you want to take in the lounge shower. GTFO already.
Tourists treating it like a day spa.
#fifo problems
not sure if virgin has same,
but Qantas first lounge does have a day spa
http://www.ausbt.com.au/qantas-first-lounge-spa-new-treatments-more-preflight-pampering
katie said it was quiet nice.
only done PI twice I think.
but yes suspension and brakes is where its at.
when I know I can 100 percent know what will happen when I do something gives you the chance to throw it in harder.
and the boys at pedders got my set up to just where I like it.
was fun they gave me a good baseline, then went back a few times with feedback on what the car was doing and they dialed in what I was looking for.
suddenly it all came right and made the car awsome to drive.
going to spend most of this year getting it back to this state. then aim to go faster.
I can understand the need to try and fit more people in for a spa treatment, but 20 mins does seem quite short. Just as you are starting to attempt relaxation and unwind,your time is up! The treatment would feel rushed, defeating the purpose of unwinding and relaxing.
50 mins though was a bit overboard. I think a 30 minute treatment would be the ideal sweet spot, between actually having a decent treatment and providing more appointments.
Could someone by the way please answer for me if the opening times for Aurora spa going to change I.e. Possibly extend opening times.
It doesn't get much more first world problem than that
Google'd best 1st world problems and this came up
I work in a shared office, and to get in you have to wave your ID card in front of the reader to unlock the door. Normally, you can just leave your card in your wallet and wave your wallet in front of the reader and it works.
One day, my coworker (who's in a higher-paid position than I am) complained that the reader couldn't detect her card through her wallet because she had "too much money in there."
Sometimes, life is hard.
  • Like 1
Does +$400 and some bargaining get a Samsung or Sony tv down to kogan pricing levels?
not quite but the difference is small enough that I won't care.
thinking this one:
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/samsung/samsung-ua55h6400aw-55-full-hd-smart-3d-led-lcd-tv/552561/
edit:
and the kogan equivalent:
https://www.kogan.com/au/buy/kogan-55-agora-smart-led-tv-full-hd/
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
