*ahem* engineer whose specialisation is statistics checking in & you reference the lawyer
Lawyers are wordsmiths like myself and Hamish is Hamish; my apologies.
Please accept one student copy of SPSS as a goodwill offering.
B.Soc.Sc major in T tests
I was surprised when they changed the rules regarding to teachers from needing a diploma to a degree. Suddenly it's a much bigger commitment and time to become a teacher. Do you think it will increase the quality of teachers due to this?
Hmmm that one can sometimes take the input shaft with it, hopefully not yet and it's just on it's way out.
Outside chance, but can also be a clutch issue. Thrust bearing another slight possibility if it's rattling around on the input shaft retainer because it's slightly touching the pressure plate (a good way to test out this one is to put a small amount of pressure on the clutch pedal so that it presses the bearing firmly up against clutch, but doesn't engage the clutch...if noise disappears then it's probably this. Otherwise input shaft / spigot bearing is your culprit.
Might as well do rear main while you're there too.
Thrust bearing sounds very logical as I'm pretty sure the noise went away as I touched the clutch peddle.
Rear main was done with the new engine so should be good.
That's good news hopefully then
Just a semi box out job and hopefully it was just noisy and hasn't chewed away at the input shaft retainer, not that these are particularly expensive
  • Like 1
no
Yep
Can't guarantee that, but can guarantee there are heaps of lazy, uncommitted teachers who got through on a diploma and want a quick career in something they aren't particularly passionate about. Leesh has mentored quite a few teachers doing their student prac with her and it's always the diploma students who are the worst.
May mean a potential shortage in future, but yes I'd expect the quality to improve. Really no different logic from making med students do 6+ years of uni.
  • Like 1
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
