I like these:
http://www.importmonster.com.au/shop/product_info.php?cPath=40_45&products_id=1899
What's the price look like for you guys, what would you pay..?
Also.. Is it possible to shave a couple of mm off a wheel to make it a few mm higher in offset?.. Sounds dodgey but dem rears will poke out hard and I want to run big tyres.
Edited by UNR33L
Dude with a gun & no will to live has no relevance to a billionaires life
But sometimes a lot of relevance to his death
http://www.dailyfinance.com/2010/06/22/bad-fortune-five-bizarre-billionaire-murders/
I like these:
Hamish will tell you to harden the fk up, particularly as they are professors
i was considering shaving off offset... bad idea. you're not shaving off offset, you're removing meat that sits on the hub/wheel studs.
just roll guards/sort out suspension, fit tyres that fit etc. you'll be fine
I like these:
Harden the fk up
Especially as they are professors
D1Rs come in all sizes and offsets
Yeah but only one magnitude of gay
Lee even like 2-4mm would f**k it you think?
Birds d1rs in 20s look sheit!
Lol
Sif 2-4mm will make a difference fgt
That will get you 1 tyre size up which you will never notice.
4mm would be acheived with a guard roller and about 2.3 seconds
Lol.
Aaron has already rolled them for me, maybe I'll go down to import monster one day and try them on..
You had professors? thought you were rocking varrstoens
I want to at least fit some 265s f**k those 225s and 235s what am I gonna do with those lol
Edited by UNR33L
Engine build complete after many dramas.
'greg can you come here and tune the start'
Rock up with laptop
Play with ECU
car starts... and appears to run/idle fine/way smoother than it did before it died, no smoke, no leaks, just... purring away
f**k, expect 7 years of bad luck now everyone
I'm sorry
D1Rs birds?
11025186_690767431046669_180923112286857
That actually looks pretty tough.
People may diss them, but they are lightweight, cheap and can take a beating. Break or rash one and $250 to replace.
Lol.
You want to shave 2-4mm
Thats going to be the difference between a 255 and a 265.
Or a 235 and a 245
Etc etc etc
What on earth makes you think shaving 2-4mm will allow an extra 20mm?
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
