well if you being a pansy
http://www.triumphroverspares.com.au/page.asp?parentid=5&parent2id=16&parent3id=19&productid=68
based ont eh rover 3.5L v8..360kw
but if sunbeams came with USA v8's and ddesigned to fit a 427 anyhow.. why not?
http://www.hotrod.com/cars/featured/hrdp-1003-big-block-sunbeam-tiger/
lol @ rover V8.
yeah thats what im talking about. but less cobra, more clean/subtle.
will look into 427.
so far my only thoughts are: bigg-ish V8. manual. EFI w/ ecu. maybe ITBs.
Yeahhh m8888 V8's!
Fark the JDM's
Saw this on friends facebook post. Apparently the admins drive ADM Jap cars
*Note not a member of the club, there seems to be a billion different facebook groups
11050234_1053838521299984_76916896089164
So if I understand his English correctly...they're banning Evos GTRs Stageas GTIRs etc. from their club?
Guy sounds like a professional, from a professional car club.
Nissan make ADM cars? I thought they were all imported from Japan... Or perhaps Korea... Or possibly China.
Anyway, the Stagea isn't gay enough to participate in Facebook groups, or anything that has JDM in the name.
  • Like 2
lol @ rover V8.
will look into 427.
so just buy a muscle car????
corvette Convertible sounds like would work perfect.
http://www.ebay.com/itm/Chevrolet-Corvette-CONVERTIBLE-1974-chevy-corvette-convertible-4-speed-350-small-block-numbers-/201307281265?forcerrptr=true&hash=item2eded95771&item=201307281265&pt=US_Cars_Trucks
much cheaper than building what your thinking as well...plus can put side pipes on it!!!
yes you can actually get a Aust made skyline:
http://en.wikipedia.org/wiki/Automotive_industry_in_Australia#Nissan_Australia
but ADM does mean Australia domestic Market, so cars made for sale by a manufacturer sold direct in that area, no specifications on where they were build.
thus there ADM and JDM S15's both build and brought in from japan just some grey import and some ADM as sold by nissan.
I could have just bought a V6 statesman for $3k. But I got the Gloria instead. Becoz it's awesome.
Could just get a sunbeam tiger fully restored for $50k+ but I would rather rat the duck out of an alpine and put a big V8 in it
"The lower price [iron Ore] means service industries such as tourism and education have overtaken iron ore as Australia's biggest export earning sectors for the first time since explosive growth in China's steel industry a decade ago ignited a mining boom, according to the Reserve Bank of Australia.
Demand for iron ore is set to soften even more after China recently set its lowest target for economic growth in 15 years.
Iron ore miners have been counting on a drop in output from outdated and inefficient Chinese mines to help toughen a soft market but this month acknowledged that process, too, is slowing"
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
