Bank valuations should never be made privvy to the client although some banks allow it.
It's for litigious reasons.
I wpuld never let a client know... you think it's bad for a house try explaining to someone you aren't telling them what the commercial val is when you just charged 10k for it :P
capped repayments?
So why don't NAB just offer it themselves...
How low you rekin I could get CBA to drop it (without capping repayments), and what's the best way to get em to do it?
CBA, just speak to them. They are some of the best with rate matching. Their bankers have more pricing discretion than most.
Yeah but do I need a rate from someone else for them to match? Or just call up and say I want it lowered or I'll go somewhere else
You've confused me with the LVR shit now too, I'd imagine it's better to have a lower ratio, ie you owe f**k all but your house is worth heaps...
Pretty sure I'm well under 80% even without knowing the value of this place
Even if it hasn't gone up a cent since I built it, I'm well below 80%.
They're selling blocks of land across the road for a new estate, might go sus out what they're worth to give me an idea of what my block is worth now
Just go in with U bank's offer and tell them you will jump ship but would like to see if they can match it or at least come close as you really like the CBA service.
They wont beat it, but they might drop your rate
Banks value at contract price - for purchase anyway never more and almost never less unless you over pay big time
Capped is shit I went variable cos same problem could only pay max 5% over per annum how spose to pay off fast with that shite I'm with Macquarie think the variable is down around 4.5 now they sent me a letter the other day but eh just keep payin same as original
They sent the valuer out to inspect so I don't think they're going off what I paid... If they take into account shit I've done like landscaping, concrete, air con etc it'd have to be worth a bit more than it cost to build, and I'd say the land has gone up even if only a little. Will have to sus out the blocks across the road to get an idea...
She said she's pre approved me for around $400k to buy a rental so I can't be doing too badly in their eyes.
Have since changed plans since meeting with her though.. Instead of buying a place solely to rent out, I figure I'll buy a block in an area I wanna live, build a new place there then rent this one out... Just need to find a wide block in the area I want, need the width to fit a triple garage..
Banks usually hand out pre approval at 80% LVR.
Talk to a mortgage broker, they'll push it to 95% LVR; meaning greater loan for smaller equity/deposit.
Yeahhh m8888 V8's!
Fark the JDM's
Saw this on friends facebook post. Apparently the admins drive ADM Jap cars
*Note not a member of the club, there seems to be a billion different facebook groups
11050234_1053838521299984_76916896089164
My cars so ADM it's even on my numberplates
YbIba9J.jpg?1
But I bet being turbro would still be allowed in their 'fancy' JDM tyte yo club.
With higher risk and likely worse rates.
No one (virtually) is going to lend at 95% without LMI which at $400k will slug you an extra $8-10k
As an investment property that you may want to sell at any time depending on the market it is unwise to gear it so highly. For an owner/occupier it's more logical as you intend to live there for a while.
Also Simon fast n loud is a sick show!
I recommend getting on it peeps.
Farken Optus, find out 2 weeks after signing up for another 2 years of fetch tv that discovery turbo has been dropped from their line up...Not happy
Has anybody tried this new Maxthon browser...seems pretty good so far..
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
