Variable? Don't want a cap on repayments... Last time someone told me to look into the wealth package from commonwealth, that was the deal breaker
Don't know, give them a bell or hassle them on their pop-up window chat.
Whats wrong with a minimum payment? A lower interest rate means you are paying off more with the same amount of coin.
Mines an interest only variable loan :thumbsup:
Best way IMO
yeah think that's what i got
in other news.. going to bali in 2 weeks for a holiday, which areas should I visit?
Dirtbike - check, Ford/Holden V8 - check, VBs in fridge - check, Bali - work in progress..
  • Like 1
I want to be able to pay off as much as I want... Most fixed rate cap the repayments at something like 10k p.a or something...
Best way IMO
Is this on a rental?
Never understood the point of interest only...how can it be a a good thing to never own the house and pretty much just pay 'rent' to the bank
exactly you might as well pay rent to some poor sucker with an investment property...at least that way you can feel like you are helping somebody who needs it...though all his money is probably going to the bank anyway....its a vicous cycle and the bank usually ends up with all the monies either way
not custom. fluke.
nice....might have to go down the local vicroads and see whats in the drawer...
I don't think you understood what I was saying
Toby might be putting his money elsewhere for the time being but wants to keep the house he has purchased
I'm surprised the possibility of investing in something OTHER than real estate hasn't been raised at any point in the preceding 5-10 pages lol
Hit yonica with the stock tips Monica
ah I get ya. You could always refinance to 20-25yrs as opposed to 30yrs? That would make it a bigger repayment each month.
The cba chick that handled my stuff said to do interest only on the investment property while I was still paying my own house off, which made sense, but if it's your only one then I don't see the point
+1 will be refinancing my investment to an Interest only and P&I for my house
My boss has been in the FIFO professional game for 10yrs.
Had invested all his money into stock market. Made an absolute killing.
Would tell me stories how he would drop $60k in one company & double it in 3 months time etc
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
    • OR, Tell the Motec to STFU, you said shift, so try shifting! But then yes, I agree, more sensors needed to. Put either a wheel speed sensor, or a diff speed sensor on it. Then get an input shaft speed sensor too. (I say input shaft speed, and not engine RPM). This way, you can now also log and see if the clutch is slipping (RPM, vs input shaft speed), and you can calculate gear (Input shaft speed / Output shaft speed). At least then if the gear position sensor fails you have a backup. And realistically, the Motec should only worry about what gear you're in for the parts where I'm assuming you have some power management strategies in it for the lower gears. (IE, lower boost, maybe different throttle curves, different ignition curves, etc etc). But it should stop it shifting. Pull the flappy, that f**ker should just attempt the motion! Heck, even on a sequential like on a motorbike, you can keep trying to kick it up a gear all you want, the physically part of the box takes care of not being able to loop the whole way around the box! Only part you'd have to worry is how it gets to reverse.  But that's on the driver... An R32 shouldn't be so smart as to try and override the driver on a gear shift
    • Yeah, nah. Anyone not putting the absolutely largest battery that will physically fit (ie, NS70 X) is not thinking straight. the NS70 X is close on double the capacity of the "stock" unit.
