that be June:
http://www.sau.com.au/forums/topic/452502-2015-motorsport-championship/
hoping to have a GTR ready?
Or finally find out how slow the GTS-t is on a track .....
Them's fighting words!
Maybe you're right though, with those heavy cast D1Rs and all
that be June:
GTS-T will hit the track before the GTR does
And if it's slow it'll be the driver, thing is reasonably well set up for a daily
would like to come to sandown, but got shit on :(
gloria off to Centreline Suspension for JDM treatment. i was surprised chris knew what was going on before i had even said anything "so we're going to need a lot of negative camber, and you dont mind if it exceeds 100mm ride height?"
take a lot to get a gts-t around a track quick,and if it a good daily then it's not there...just ask Simon.
dialing out the understeer of such a heavy motor at speed is very hard.
It's a manageable daily. There are much more friendly cars going about on the street, but people are surprised when they drive it how palatable it is for the power output and how quick it can be putted around mountain roads. I modified it with the intention to make it capable and retain some creature comfort - expensive process and ultimately a compromise for the street is usually a compromise at the track, yes, but even things like 0 camber for a street setup, tyre and brake pad choice...things I can easily change before a track day...make it a better daily driver.
Adjustable everywhere and poly bushes throughout, the KAAZ 1.5 way is wonderfully predictable and helps her to be tail happy when you want it to be, really helps with turn in at moderate to higher speeds and the opposite at lower. Granted I'm not doing 160km/h corners on the street, but it'll be interesting to see how the car goes nonetheless. I think the suspension would be the thing to hold it back given the struts sound a bit shot after years of Toorak Rd. If nothing else I still have a decent whack of power to make use of our long straights. Could always give a better driver a chance in it and see what they think.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
