Drive your ute to Deakin University
Sit there overnight with indomie noodle packs in the tray
Drive back to western suburbs and onto vacant blocks of land
Throw more indomie noodle packs on the ground
Drive home and watch Goodfellas while your property value skyrockets
I like Shark Fin in little bourke, but a bit $$ so not go there often.
for a casual one we go to dragon boat palace on lonsdale street., it;s something like 16:80 all you can eat.
get there about 11:45 for all the best stuff to come out.
So...talk to pedders about the car.
first time suspension looked at since:
go over the whole car..no bent arms, bushes fine, mounts ok..
only thing they could find was some stiffness on the pillowballs from sitting 2 years so they ust cleaning thema nd will be ok..
Tire Bundles rock.
  • Like 1
Watching If You Are The One and a dude just rocked up with a gift (as most do)... But he brought a document of his life insurance in his favourite girls name, so she could sign it and become the beneficiary of 150,000 yuan incase of death. Wtf
Even if he is an insurance salesman... People are delusional
Tire Bundles rock.
Lucky the GoPro was on the other side of the car. Could have lost some money there.
  • Like 1
Looks like around 30 blocks sold already, people there constantly, don't think they're struggling
Yeah work off the highest advertised price for same size bank will knock it down if they need to but for re finance they always over value - if they think you can cover it Edited by alr33x
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
