I don't wanna go fixed and have the repayments capped...
What's a realistic variable rate to go for Hamish/others with lower variable rates than me?
I'll call em up and if I can't get it or near it I'll bite the bullet and change banks. Might move all my accounts, credit cards, insurance etc too
Just have a look around Dezz...
Ubank are offering 4.29% comparison. It's also a safe option as they are ALWAYS one of the lowest.
CBA won't do much to help. It's always worth asking if they can match Ubank, but it's a big jump.
They are good with minor pricing discretion, but half a % might be pushing it.
CBA don't WANT to be the cheapest, which is why they aren't. With CBA you get a service that other banks can't offer, but it is never the cheapest.
Still look into fixing dezz. With current rates it's the right time as it's only going up. Just need to find someone that offers a good fixed rate WITH a 100% offset account. Not all lenders do them but it gets around the extra repayments issue.
Just need to be 101% sure you aren't going to want to sell before the term is up.
I don't even know what the comparison rate means. If it's not the rate I'm getting, why are they quoting it?
What service is that exactly? I'm not unhappy with CBA, apart from wanting a lower rate, but apart from actually lending me the money, they don't really do anything else for me service wise..
Plan is to keep it as a rental if/when I move onto something bigger/better ...
I gather a fixed rate loan with a 100% offset account means my extra repayments may be capped, but I just put that money in the offset account which is the same as paying it straight onto the loan anyway?
At the moment I just put it on the loan (pretty much just use my home loan account as a savings account)
Comparison rate is the total of what you pay (fees, charges, interest) expressed as a percentage for the purpose of comparing products.
In a nutshell it is now a legal requirement to display it and it is the only figure you should be looking at in 99% of cases
Mostly fluffing... It's just that you walk into any CBA and you get served very quickly, loan apps are processed much faster etc.
it's nothing that you "need" however it's their business model and their shares are worth 11ty billion so it's unlikely to change in the near future.
Personally I don't care for "service" and am happy to go with a bank that takes longer but is cheaper.
Exactly... which is why most banks don't offer it, or if they do it's a 1 or 2 year deal only.
Just be sure to check the exit fee situation if they offer 12 months only as you may want to move once the welcome mat is pulled out from under you.
  • Like 1
I rarely go to the branch, i'd say maybe once every month or two if that, and it's usually on an RDO so rarely busy anyway..
I'll have to call up and see what they'll offer... It'll drop to 4.75% on the 13th but pretty sure Tobes said he was getting like 4.45% before this latest cut
Yeah only got that low as I had in writing an offer from NAB
Otherwise I would be on about 4.65% i think (before recent rate cut)
I was on 4.55% less rate cut .22% = 4.33%
bitchs please..
what you want is the one where the Booze is refilled automaticly...
http://www.autoblog.com/2009/09/26/holland-and-holland-range-rover-by-overfinch-gun-and-booze-haulin/
thats pretty cool.
Dan Murphys dont stock Ivan The Terrible vodka :(
this beamer has a little vent in the glove box, that can constantly blow cold air into it, to keep drinks chilled.
what a time to be alive.
nigga pls... my nissan has that shit
I'm on 4.6 at the moment haven't been notified of any change with recent rate cut presume it may drop .2-.25
My mate had same model 530 you just got .. I drive shit itself after an update 7k down the drain.
Would never by a 'prestige' car without warranty Tis asking for trouble
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
