I don't wanna go fixed and have the repayments capped...
What's a realistic variable rate to go for Hamish/others with lower variable rates than me?
I'll call em up and if I can't get it or near it I'll bite the bullet and change banks. Might move all my accounts, credit cards, insurance etc too
Just have a look around Dezz...
Ubank are offering 4.29% comparison. It's also a safe option as they are ALWAYS one of the lowest.
CBA won't do much to help. It's always worth asking if they can match Ubank, but it's a big jump.
They are good with minor pricing discretion, but half a % might be pushing it.
CBA don't WANT to be the cheapest, which is why they aren't. With CBA you get a service that other banks can't offer, but it is never the cheapest.
Still look into fixing dezz. With current rates it's the right time as it's only going up. Just need to find someone that offers a good fixed rate WITH a 100% offset account. Not all lenders do them but it gets around the extra repayments issue.
Just need to be 101% sure you aren't going to want to sell before the term is up.
I don't even know what the comparison rate means. If it's not the rate I'm getting, why are they quoting it?
What service is that exactly? I'm not unhappy with CBA, apart from wanting a lower rate, but apart from actually lending me the money, they don't really do anything else for me service wise..
Plan is to keep it as a rental if/when I move onto something bigger/better ...
I gather a fixed rate loan with a 100% offset account means my extra repayments may be capped, but I just put that money in the offset account which is the same as paying it straight onto the loan anyway?
At the moment I just put it on the loan (pretty much just use my home loan account as a savings account)
Comparison rate is the total of what you pay (fees, charges, interest) expressed as a percentage for the purpose of comparing products.
In a nutshell it is now a legal requirement to display it and it is the only figure you should be looking at in 99% of cases
Mostly fluffing... It's just that you walk into any CBA and you get served very quickly, loan apps are processed much faster etc.
it's nothing that you "need" however it's their business model and their shares are worth 11ty billion so it's unlikely to change in the near future.
Personally I don't care for "service" and am happy to go with a bank that takes longer but is cheaper.
Exactly... which is why most banks don't offer it, or if they do it's a 1 or 2 year deal only.
Just be sure to check the exit fee situation if they offer 12 months only as you may want to move once the welcome mat is pulled out from under you.
  • Like 1
I rarely go to the branch, i'd say maybe once every month or two if that, and it's usually on an RDO so rarely busy anyway..
I'll have to call up and see what they'll offer... It'll drop to 4.75% on the 13th but pretty sure Tobes said he was getting like 4.45% before this latest cut
Yeah only got that low as I had in writing an offer from NAB
Otherwise I would be on about 4.65% i think (before recent rate cut)
I was on 4.55% less rate cut .22% = 4.33%
bitchs please..
what you want is the one where the Booze is refilled automaticly...
http://www.autoblog.com/2009/09/26/holland-and-holland-range-rover-by-overfinch-gun-and-booze-haulin/
thats pretty cool.
Dan Murphys dont stock Ivan The Terrible vodka :(
this beamer has a little vent in the glove box, that can constantly blow cold air into it, to keep drinks chilled.
what a time to be alive.
nigga pls... my nissan has that shit
I'm on 4.6 at the moment haven't been notified of any change with recent rate cut presume it may drop .2-.25
My mate had same model 530 you just got .. I drive shit itself after an update 7k down the drain.
Would never by a 'prestige' car without warranty Tis asking for trouble
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
