Fair call
In which case I think you should take a look at it
These cars will be worth their money one day, mark my words. The most popular model of Skyline and all of them thrashed out / parted out or written off one day. Will be the new VL turbo but not a piece of shit.
  • Like 1
Decent respray is a 4k+ affair, I reckon that's a worthwhile addition for a near 20 year old car if it's a good colour/job
But hardly any mods is why I don't think it's worth anywhere near 12k - would expect at least ecu / injectors / turbo for anywhere close to that
But that's why I don't think it's worth anywhere near 12k - would expect at least ecu / injectors / turbo for anywhere close to that
I'm not saying it's not a nice looking car, just that there's nothing really done to it that make it look any different from the other 3 million S2 R33's around, apart from the wheels, which aren't included.
The thought of buying a skyline sometimes crosses my mind... If I was to go down that path instead of something much pricier like M3/AMG/35 GTR etc, it would more than likely turn out to be quite an animal..
But alas, I think those days are behind me
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
