That was the other thought I've had... 32 gtr club regd and off its dick. But being so old I'd wanna pretty much replace every part of it... I'll just end up getting something much newer... One day
Just a thought, 1995 R33 GTRs are 20 years old now, could do that so you don't get aids interior
edit: oh just realized it has to be 25 years not 20 :(
Edited by UNR33L
http://www.heraldsun.com.au/leader/outer-east/a-man-who-took-an-innocent-selfie-at-westfield-knox-has-his-image-splashed-all-over-facebook-by-a-mum-who-thought-he-took-photos-of-her-children/story-fnrwkhlp-1227342634069
Story about some innocent man at knox shopping centre getting grilled on FB
Saw this on FB with people on my list. For the Knox suburb, South east brahs
If I was that bloke I would have plastered her face all over Facebook and just labelled her a karnt.
Simon 100% no passenger laps tomorrow? I wont bring my helmet then!
Dezz what company do you recommend for phillip island track days on the bike? thinking of taking the MV around.. fun times into turn one?
FArkn bored house wives are a scourge on society
  • Like 1
But then you'd be in the news, ACA, herald sun, 60 minutes and a jail term too
Reminds me of the bored old hag that had a go at me for parking in pram parking, f**k off bitch there's a heap of spots around
I'd think you'd be a dick too, just like people parking in disabled spots :/
Saw an ad for an upcoming ACA story lastnight
The people who dress poorly for their court appearances...frustrating and angering magistrates left right and centre...and why you should be concerned about this!
inb4 expose on the common cold and why you should avoid getting sick
As I am sure I said last time... THIS is why no one likes Gen Y
  • Like 1
Now that's an ACA story I can get around Edited by HEKT1K
Why are they so angered by the dress code?
Shouldn't determine if you are guilty or not.
I can understand to a degree magistrates getting upset at people not dressing nicely for court...not that everyone can afford to...
But why ACA give a shit or think the public do is beyond me
Fair enough
But lets not diverge from the topic at hand that Leigh is a karnt
Sounds pretty good to me... means if I ever have to go to court for something and I wear a suit, I'll be recognised for the upstanding citizen that I am...
Ric can I borrow your pink knickerbockers?
So hard for the stupid bitch to confront him in person about it and give him a chance to explain
Better to shame him on social media and people make their accusations
  • Like 1
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
