But will you like the increased guy attention
Increased nobody attention moar liek.
Occasional glance/thumbs up from another turbo subi owner otherwise pretty much nobody looks at it. Really is a WRX in grandads jumper and it's so good. Pulled over driving it once on my P's and cop let me off with nothing even though I could've lost my license. Been through 2 breathos and even with a loud exhaust just go through like anybody else. Less police attention than the quiet as a mouse bog stock NA 4 door skyline. Less joe average attention too.
turbo subarus before they were cool.
ive never seen anyone thumbs-up any other car ever before. actually, except when someone on a bike thumbs-up when i was in an exige.
all i ever see is this:
or
The car I've seen the most thumbs up while travelling in has been either of my dad's Cobra replicas
They seem to be universally appreciated by all kinds of people of all ages and people love making it known to you
Second was a mint condition HT Monaro GTS with a 427 that I took for a test drive...bogans were hanging out of their cars for that one
What do i need to 200awkw it?
If it's an original RS engine afaik the heads don't flow all that well soonly capable of ~180kw atw.
Plenty of em had the noisy lifter recall(Which only happened if people complained) where they stuck early WRX heads & pistons. Those or anything else shouldn't need much. Fairly usual stuff, TD05-Big 16G/18G/VF23/VF22/VF34 etc, fuel pump, injectors, 3" turbo back, tune, maybe an fmic.
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
