its funny, but the lack of faith in the youtube comments is disturbing.
pulsar gearing will do 240. everyone knows that. its getting the power and length of road to get there that is a challenge.
Edit by Admin:
Edited by Odium
Accuracy
  • Like 1
in 6th at 6000rpm I could do 392km/h apparently going off the gearbox / diff ratios (according to ford forum)
wonder what it'd actually go to with the resistance - anyone wanna find out for me on Achilles?
Edited by UNR33L
Edit by Admin:
Do it fgt
Btw non turbo 2 litre Calibras topped out at mid 230s thanks to their aerodynamics and torque
Needed a long ass freeway to test that theory out
very funny simone.
please note: the pulsars speedo stops at 240 and i got a bit over 230 at PI. now with more powah, should be able to get there. (whether that is legit 240 or not is questionable, but case in point is going off the speedo. according to old-man withers)
It's a little too easy to hit the 180 max speedo on the skyline at the track... though, PowerFC reports speed at about 170 when that occurs, and GPS backs up its claims.
Makes me sad in the pants when I get in a Micra or something and it's got a bloody 240km speedo :P
Just went and had a look, few people have mentioned 33GTST Manual would be at 270km/h @ 7000rpm 5th.... Wonder how long it'd take to get to that speed.
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
