Got into counter strike this week.
I enjoy the friendlier-smack talk, but fark me it's a sad world. Thousands of hours of play time, sitting on the same map, using the same weapons.... Worse than wow almost. Except it's stimulating (for a few hours)
I would agree but my nihilistic views on life prevent me from being a hypocrit - almost everything anyone does can be comparably sad. I tend to favour games as at least an active participation rather than the passive nature of say watching tv for hours on end which seems to be most of people's lives these days if not on social media.
this is true.
i look at my steam profile and then look at other peoples... i play a fair few hours a week compared to some, but I havent put more than 150 hours into a single game. whilst a friend of mine put 800 hours into one of his Diablo 3 characters, and has several characters. i just cant fathom how people spend so much time on something with so little interaction (when you think about it) and so little rewarded (other than more games).
Some guy replied to my comment on there this morning, which Facebook notified me of, but doesn't take me to the reply making the notification pretty pointless... I'm guessing he was disagreeing with me agreeing with bolt.
In short, f**k Adam goodes he's a f**kin sook. If it's racism why aren't they booing his aboriginal team mates?
Simon Carter But they never stood upto a girl for yelling out a racist remark
Simon Carter plz
ABS will have the raw figures, not sure about targets / projections. Why?
Apparently it's around 3%
An independent study has shown that the construction industry runs at around 6-6.5%.
So your boy Abbot wants to strip us of all our rights/benefits because we're all lazy unprodcutive bikies, running at double his desired productivity.
Blow me Tony.
I just got a payrise :)
this is true.
I don;t get why ppl play games when they could be living a life?
want to shoot things join the army
join a gun club
go bush and find a deer
want to race something go out on the track.
do something that has a consequence at the end not a reset button.
join a gun club
not everyone is
a) old enough
b) has enough money to do those things
c) not responsible enough
d) mentally stable enough :P
deer tracking is also extremely difficult and time consuming. i dont really feel like killing things (except rabbits or foxes) unless of the communist variety.
im actually going shooting this weekend. never used a rifle before, we'll see how we go against some precious antique cans.
Double negative suggests you do in fact have time for laces.
Why then did you buy shoes without laces?
All the double negative implies is that the number of people who have time for laces is greater than zero. I may or may not be one of those people
Also I bought them cos the tassels are pimp
Laced
#limitededition #shoes #nike #infrared #air #max #airmax #nikeair #yeesy #notnikeidred #hashtag #indstagram #instashoes #instanike #limited #rare #feet #tattoo #legs #redwatch #copped #coppednotdropped #union #red
I tell it how it is cause I'm a bold figure
And I hate a money hungry girl a.k.a. golddigger
It ain't even funny
Some girls don't even know me askin me can they get some money
I'm lookin nuthin like ya poppa
I wouldn't give a chick 10 cent to put cheese on a Whopper
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
