RE: that LeMons race get heaps of press lately...
Read the regs inc the fine print......
$880 per driver. Min 5 drivers. $4400.
Then they charge $75 per pit crew member, and $30 each for anyone else.
$1000 car that needs a professional cage, race seat, 6 point harness, fuel cell.....
Drivers must have 3 layer suits or single layer and underwear, Hans device and helmet.
Add basic maintenance stuff to the car, tyres, brakes, fuel, and whatever else, get there, stay there, and come home.
Not so cheap now
So probably paying like 2k each once you add all that up / mods etc (and the need to find 4 others that are willing to drop 2k on a shitbox rally basically)
2k would get you a decent sim racer for home :P
Edited by UNR33L
Add the fact no one will actually be racing in a car they bought for $500; impossible to prove any sale didn't occur for that
apparently its not a receipts thing, its a estimate value thing. like, even if you didnt pay for things, its value is determined (somehow)
Think I'd have more fun buying a good set of semis + pads and hitting up PI on a normal trackday.
Speaking of which, havent seen you at the track ever.... get out there with the e85 drag monster you keep talking about
  • Like 1
Calder or Heathcote?
I really want to do PI but Haunted Hills doesn't look half bad either. When is the next of either (can't make SAU Vic June PI)?
Edit: scratch that, I don't want to bin my daily until GTR is on the road.
PI is Sunday June 14th (Also 13th, but we're not attending the untimed "testing" Saturday)... Check the Motorsport calendar in the VIC section for the other upcoming Championship Round days :yes:
I won't be attending this round anyway... Things escalated in the garage the other night
I come along with you to one of the other rounds
I really need a race seat though
Sunroof + 6'2 + helmet don't work with the stock seat
Got the opposite problem... Try driving a car that used to be owned by the tallest hipster I know, who put lowered seat rails in it, so I need to stretch to get my legs to push the clutch all the way down.
We swap cars?
Not so cheap now
yeah i saw this lasty night as well...
f**k that, its lemons racing, way cheaper in the US of A
i could buy nismo afms for the r32 so borci can bar up instead.
  • Like 1
If you had the stock rails you would be even further away from the firewall.
The problem is your legs
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
    • There are guys on Facebook under, Infiniti Owners Australia   https://www.facebook.com/share/g/1Z3RbPqx4k/?mibextid=wwXIfr What Whp are you after and I can help, and join this Q group in the states. https://www.facebook.com/share/g/19A59cN3JR/?mibextid=wwXIfr
    • Does any of you guys have instagram pages for your builds? Keen to see some Aussie builds. I still can't figure out how to post photos in here.
    • That awesome thanks for that.
    • You can Remote any of these VR30..globally  Check: AMS Performance | Racebox | Sonic Tune | Soho | Z Motorsports | Specialty Z    Performance Parts | AMS | Z Motorsports | Boosted 6 |    Exhaust | Fast Intentions | ARK | MBRP Motordyne | Borla    There is someone in Sydney with 650whp   I am at 430whp without flex fuel, but FBO & Flex-fuel will push you to 500whp!!
