RE: that LeMons race get heaps of press lately...
Read the regs inc the fine print......
$880 per driver. Min 5 drivers. $4400.
Then they charge $75 per pit crew member, and $30 each for anyone else.
$1000 car that needs a professional cage, race seat, 6 point harness, fuel cell.....
Drivers must have 3 layer suits or single layer and underwear, Hans device and helmet.
Add basic maintenance stuff to the car, tyres, brakes, fuel, and whatever else, get there, stay there, and come home.
Not so cheap now
So probably paying like 2k each once you add all that up / mods etc (and the need to find 4 others that are willing to drop 2k on a shitbox rally basically)
2k would get you a decent sim racer for home :P
Edited by UNR33L
Add the fact no one will actually be racing in a car they bought for $500; impossible to prove any sale didn't occur for that
apparently its not a receipts thing, its a estimate value thing. like, even if you didnt pay for things, its value is determined (somehow)
Think I'd have more fun buying a good set of semis + pads and hitting up PI on a normal trackday.
Speaking of which, havent seen you at the track ever.... get out there with the e85 drag monster you keep talking about
  • Like 1
Calder or Heathcote?
I really want to do PI but Haunted Hills doesn't look half bad either. When is the next of either (can't make SAU Vic June PI)?
Edit: scratch that, I don't want to bin my daily until GTR is on the road.
PI is Sunday June 14th (Also 13th, but we're not attending the untimed "testing" Saturday)... Check the Motorsport calendar in the VIC section for the other upcoming Championship Round days :yes:
I won't be attending this round anyway... Things escalated in the garage the other night
I come along with you to one of the other rounds
I really need a race seat though
Sunroof + 6'2 + helmet don't work with the stock seat
Got the opposite problem... Try driving a car that used to be owned by the tallest hipster I know, who put lowered seat rails in it, so I need to stretch to get my legs to push the clutch all the way down.
We swap cars?
Not so cheap now
yeah i saw this lasty night as well...
f**k that, its lemons racing, way cheaper in the US of A
i could buy nismo afms for the r32 so borci can bar up instead.
  • Like 1
If you had the stock rails you would be even further away from the firewall.
The problem is your legs
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
