Haha I doubt it. Given the premium he paid for the land I'd say he's after the actual location instead of trying to make a profit. House is pretty bespoke too
There's one up the road on similar acreage that has been vacant since the early 90s (Chinese-Australian owner lol)
They should give him and other members a payrise. If he wants his first home to be in Kew then he should be given every oppurtunity to make that a reality.
Scratch that his a liberal mp apparently.
Ol mate hockey have to chip in for him
Edited by alr33x
http://www.businessinsider.com.au/mother-of-two-calls-out-treasurer-joe-hockey-with-an-open-letter-doing-the-maths-on-sydney-housing-affordability-2015-6
Poor woman had to borrow money from her family to buy her first house...shock horror
Uses as an example the most expensive housing market in the country weighed against the average nationwide wage for a single university graduate
#leftylogic
Why do people think being able to easily buy an inner city property as a single person with any old job is a god given right? And when did this mentality begin? I can't remember my parents wanting to live in Toorak on average wage - they bought on the fringe with decent jobs, which 35 years later happens to be a very good area...now!
  • Like 1
I couldn't make it through the whole article. The phaggotry was too equisit... even for a chef with a decade in fine dining...
“I’m not Jesus. I can’t turn water into wine. I’m more like David Copperfield. I can do magic with water,”
Pls die
  • Like 1
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
