As someone more inclined to drink them you really should have more
Really fighting temptation to crack one open
I literally bought a chivas 12 to stop me opening the green... i have already had 2 glasses.
I give it till the weekend
Cctv footage of evo car thieves on youtoob.... No number plates (but guaranteed to be stolen) and also a latest model corrola, just like the photos from a recent supra theft in a multi storey car park.
Hi. :action-smiley-069:
Short time poster, Long time lurker.... and your friendly local club secretary.
Membership prices are increasing by $10 each as of midnight 4th July - so if you want to renew, do it now! Just for the member priority entry to SAU NATS if nothing else (which by the way will be in sunny Victoria this year)
Thread with details in the Vic section. :yes:
you have 6 bottles why would you not open one??
what the hell else are you going to do with them.
I have 7 and I'll eventually drink one - rest will be sold for profits or given out as special presents
Shit is like dragonballs
  • Like 1
I've never seen the point in buying shit with the intention of selling it for a profit, if the amount isn't life changing...
Do it enough times in life and it is, good pocket money at least but then we ain't all on dem overtime rates
What I like is that I could sell 3 bottles and the remaining will be paid for so it's almost free goods, just a small amount of effort. Give it long enough and 1 bottle can pay for the remaining 6
But then you got honest, hardworking blokes, like Ric & I, looking to wet our whistles after a long day of business but can't find a single bottle for sale cause Birds cleaned out the store. :(
The struggle is real.
I probably wont sell any. I just love green label
Fuel pump changed - so damn quiet now. 040 bliss
Surprisingly the part that should have been easy; pulling the plastic retaining collar off, was a prick and required a $40 wrench (no getting that off by hand - still needed a heap of force on my long ratchet). And the part that took me 2 hours last time I changed the pump; trying to hook the fkin pump arm onto the bracket, was done in about 5 minutes.
Fuel hoses in the tank were splitting near the hose clamps, within the nipple and still airtight so should be okay, but might need a longer term solution for that. Alas Pirtek aren't open at 9pm.
Hamish what was that restaurant you used to work at when I picked up a stock r33 steering wheel off you? would you recommend for a dinner date?
Cosi, Couldn't recommend due to new ownership.
The new owner's other restaurant is pretty decent though - La Cita
how much you wanna spend per head inc drinks and how fancy?
Just looking for something around the south yarra area, not sure maybe <40 a head
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
