How do you drive around with broken suspension and not notice till you look under the car?
More to the point how do you have plural damaged suspension?
car has accident history? (or is this a new shell?)
"Greg"
This is a new shell.
Yes I meant the hankook RS3 sorry. If they are equiv, and $250 a tyre, well.. that's some coin saved.
re: My suspension
I hit a kerb, hard. Damaging a wheel, and bending a tie rod end.
Got that fixed and wheel repaired and new castor arms. all good.
Went under car, noticed the bracket I don't know the name of (what the front sway bar bolts to) has literally snapped off in half.
So that's nice. No idea when that happened.
I also asked TT to set my ride height at 350FR and 345R height. It felt floaty as FAAARK in the rear and I just blamed it on hicas till I actually measured the car and found the front is 330mm and the rear is 368mm.
So yeah....
How f**king hard did you hit it!? I went through a HUGE pothole a couple of weeks back. Took chunks out of both LH wheels and threw my alignment out. Gonna call the council and see what they'll do about it.
Working side (for reference):
Damaged side (for lulz):
Note: I did not notice this occur. It happened some time after traction tyres installed the castor arms and replaced inner tie rods.
Nah, ever since I got the rears put in, I noticed it felt really tail... 'rolly' as though the weight balance was 99% front, all the time. But I supplied the struts and springs to TT, as they came off the old car.
But stupid me didn't really think about the fact that while the fronts came off my old car, the rears struts were swapped, so the setting for rear height was lost when that happened. Did give them ride heights but as they (TT) figured they were swapping from one car to another they didn't need adjusting.
I had no idea the front sway was basically removed from the car via kinetic force.
If it all gets fixed up and it still feels weird then I dunno. Car didn't have that behaviour on the springs it initially came with, nor did my old car with the exact same setup.
but I'll probably blow my engine up again between now and when its time for another alignment
so this was the tyre that won street class at WTAC first 2 years.
then Yokohama sponsored and forced people on to their tyre.
so yeah it good.
That's The only prob with NT05's
The indicators coke up reeeeally fast. The trick is to not give a f**k and drive the shit out of them anyway. I used to rock mine well past the indicators
This is what I did.. although in wet you had to be real dam careful
I think I got 10,000km or maybe bit more out of them.. rears were shagged but fronts were still fine, usually I go down to the wire.. alignment Greg?
Edited by UNR33L
AD08 >>>>>>>>>>>>>>>> RS3
By far.
Why? (srs question)
Longevity?
The NT05's are just touching the indicators in the center now, on the sides there's maaarginally more, but barely enough to catch a fingernail on.
Where else to go for alignment duties? TT always been nice to me, but heard a few things now...
i havent really tried many reputable workshops in the south/east, but i still happily do the drive to Thomastown for Centreline.
Yeah i got an easy 10k from the fronts for daily duties and a few deca's. Probably would have got to 15 but I usually put them in the rears and fried them.
I disagree about the wet though. A car that needs NT05's is going to f**k you in the ass in the wet no matter what
That's a good point, when road is just wet its true it's more so when it' soaked with a few mm of sitting water even shitty tyres with channels to get rid of the water makes me feel a little better instead of a flat bald tyre aquaplaning
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
