Gee you're so impartial Ham
Sure am... ain't my fault the incumbent PM is a misogynistic, homophobic, biggoted, xenophobic fundamentalist christian turd sandwich that came to power on the back off another parties f**kup and a bunch of 3 word slogans aimed squarely ay bogan australia....
Let me know when you're done huffing and puffing, so you can acknowledge that it was your ideological compadre Bill Shorten who uttered the above (in the context of being questioned over what a slimy prick he was and is)
  • Like 1
Martin nailed it.
I have 1 teflon pan only and the resf are seasoned cast iron
Industry standard and completely non stick if you look after them
room mate f**ked my good pots and pans up with a scourer, annoyin
Draggin bikes I don't mind when people do that - never know how shit a rider could be at launching, but when cars try to race bikes playing traffic gaps, it's just dumb
I remember when I first got my R1 and outside Knox had a 911 turbo behind me at the lights - was the first time I properly gunned the bike and I scared the shit out of myself. He tried to stay with me and from that moment onwards I declared bikes to be awesome!
Have beaten a few naked 600s in my car off the lights, even a CBR600 was surprised in the traffic when I was running ethanol; asked me how much power I had at the lights. It's not impossible to beat bikes but they do it so effortlessly...really have to try with a car.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
