Only issue with Cable 100mb connections are the upload speeds being so low.
2mbps upload speeds feel crippling once you've experienced 10 or 40 or 100mbps upload speeds.
Also, contention during peak times means you can rarely achieve the throughout you're paying for, unless you're online at 3am. This is an issue on nearly every residential grade connection since people realised that you can watch tv over the internets (netflix etc)
feeling this having uploaded 11 gig yesterday
I pay a bit for mine ($93 a month) but it's decent enough.. 30mbps/1mbps 200gb cable with telstra.. plenty for just me.
Got mates at Berwick as well that can only get ADSL.. also mrs at Lynbrook can only get ADSL2
lel
Edited by UNR33L
Think our 500GB Bigpond Cable Ultimate (100mbps/2mbps) is $79.95/month (when bundled with a $40 mobile and $40 home phone)
More than enough for everything I do... I checked the other day, I'd not downloaded a single torrent in over a month... just been watching Netflix and Youtube...
Will go back to torrenting for a bit now that some shows have just started back up again that aren't on Netflix Australia :)
  • Like 1
I get like 17mbps is that any good?
Yeah that'll be ADSL2+, the maximum acheivable speed (depends on line quality / distance to the phone exchange) is 24mbps... 17 is about 500m-1km from the telephone exchange and should be stock solid stable. Can't complain with that...
Yeah I've got no need for foxtel/home phone/mobile so no bundle for me.
I'm the same, I just stream everything from Kodi (better than netflix imo because way more content, free etc.)
Only reason we still have foxtel is because it's got AFL... and of course if you want the good sports channels (and pretty much nothing else) it still costs nearly $100/month for Foxtel via Telstra.... Think it's cheaper if you bill from foxtel directly...
I use dads foxtel go account (which gets all but footy channel) but my solution to no footy channel is afl live subscription i scored for free ;) run that on my tablet and mirror to my tv = all foxtel channels free!
I've noticed that. Uploading to YouTube is a pain. And trying to stream anything other than netflix or download large files is shithouse during peak times.
I usually just download bulk series and movies and then watch them when I get time. Netflix is unmetered on Optus apparently and I have no issues with it. Except no surround sound.
I remember when downloading tv shows and movies made you a geek lol
Dem IRC days
Yes and now grandparents downloading torrents and swapping portable hard drives wtf
I remember having a pocket PC (windows ce ftw) in year 7 and copping never ending shit for it - these days you'd get bagged if you didn't have a more capable smart phone lol
me either. but then 20 hours a week of games is pretty normal for me.
Yeah I suppose I play a bit of games - used to be up around 15-20 a week, but these days more like 5
At least games are interactive and reflex stimulating, though - used to cop shit from parents for playing them all the time meanwhile they sit there immobile and passive in front of a TV for hours every night lol
    • how do you know voltage is fine?  quick easy test is connect DMM up and put it on max/min mode, remove fuel pump fuse, crank car for 3-5s, go check min voltage You'd be surprised how many "healthy" batteries are showing under 10v during this test in cold weather.
    • Not properly. You need to be able to dissipate 100 amps or so to doing it meaningfully. You can do it indirectly by watching to see how far the voltage falls during cranking. Unplug the coils or something else to prevent it from starting so you can get a good couple or three chugs. It also helps if you have the multimeter set up reading before you start, and that it has max/min functions. So you can catch the real minimum without having to watch the screen, which often doesn't update fast enough to show the real max/min in dynamic situations. Or use a digital oscilloscope, which can be obtained for <<$100 from Aliexpress (although I'd argue for paying up to ~$200 for a nicer one). A >4 yr old battery will very likely be well down the path to the knackery. Many only last 5-6 years these days. The cold weather lately will definitely make it worse.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
