Anyone excited for Batman the Dark Knight rises?
I might book some tickets when I get home for tonight if there's any seats left :/
Just saw it this morning. I'll probably be the only person to say that it wasn't as good as The Dark Knight. :/
But the soundtrack for the movie is pretty awesome
works taking me at 5 tonight..sif pay for anything
Life's tough at your work ey Martin :P
hanging to see it but got a bit on so sunday looks likely..
no spoilers kunce
Batman & Catwoman have sex
Just booked my tickets for tonight!
Come at me Batman
Intradasting, won't get my hopes up then :(
wtf??
you don;t chain it up?
insured?
was shopping for 20 min, steering lock on and everything apparently some kid kicked the handlebars and broke the steering lock then hotwired it
yeah had 3rd party fire and theft on it..
where the fk were you shopping, that's totally messed up, and naturally no-one near by did anything.
That's gayer than Mohsen's taste in wheels :(
Fuarrkkk bad luck man.
When you find out who did it, organise a wastelanders cruise to the guys house
yeah pretty shattered :( was at ringwood.. bike was opposite maccas (near peter stevens).. bought a go pro.. no need for that anymore.. little f**ker stole it! :( I guess i can strap the go pro to my dog in the mean time? Need another bike now! what get?
Loved the drz but would be haunted / think about it all the time if i got another one the same..
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
