not sure if you were still there, a wrx touched the grass coming on to the pit straight, lost it and went backwards into the wall hard.
lucky he had a cage.
I'm sure he had no idea he was dropping oil as he went past the pit entrance twice whilst it was happening!
yeh i saw that.. the red one? pretty much lost the rear end of his car poor guy.
nah the guy new he dropped his oil.. according to the towie, he'd lost 4th, couldnt take it out of gear and from what he explained to the towie, he saw the oil out the rearview.
the fact that he didnt drive into the pit but instead continue along the straight is pretty dumb if you ask me. surely you'll know somethings wrong if you cant get it out of 4th.
It's worth it every time you press the quiet button on the remote. I can't believe how quiet mine is closed, almost stock noise level, not bad for a 3.5 inch muffler. Even open it's not too bad.
Hrmm maybe i'll drop past sometime! it is something useful to have for starting up in the morning so you don't wake neighbours, cruising down the highway, having elderly passengers or driving past cops etc....lol
do it.
lol everyone jumping on the Varex wagon now...where were you two years ago when I was pushing the things. No one believes how good they are til they drive a car with one.
Good value considering the remote controlled motor setup too Birds. They do sound a bit tinny when mounted at the rear, like they have a sock shoved up the pipe. Probably best if you can get it fitted as a centre but there isn't much room there on a skyrine.
Since we are on the topic.
When fully open, what effect does this have on the exhaust flow? Something small in the exhaust even when open will have some sort of effect?
When its closed, are there any effects on choking the system? What happens when you boot the car when the exhaust is closed, are the any possible side effects?
what was that? "Mr. f**k the remote and motor ill cut it off and make my own"
well scotts tune seemed to lean out when he put the varex back on, which means it should have more flow than the 3.5" muffler he had on before.
threoretically you want the exhaust to be quiet when its closed right? so you wouldnt really be booting it anyway. but with the flap closed, the car is a laggy POS Lol
When open, it acts like a straight through piece of pipe. As it uses a butterfly valve the restriction that would put on it when open is SFA. I have the 3" Varex and ~260rwkw no issues with flow there.
When closed, they say not to drive on boost. You can give it a couple of PSI without harm, but you only need to use closed when popo are around, getting home late or cruising on the freeway to avoid drone.
Is yours a cannon type or twin tip? They do make different sounds and have different valve setups. I have no tinnyness to mine; think it helps that the rest of my system is mild steel.
Okay well that's the same setup as a canon type and they do have more of a stainless steel to them than the twin tip.
yeh the twin tips are quieter, but i heard them on a friends car and didnt like how they sounded on an sr(not that it would ever sound great - but better than its worst) but that whole sound went out the window with the .82 housing lol
and then the gate.
Guest
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
