Dear Leigh,
Thank you for your support of SAU Victoria.
My records indicate that your membership will expire on 7/18/2012. To renew your membership and receive SAU VIC Member’s-Only forum access, CAMS affiliation, exclusive discounts, attend Members-Only events and other great benefits, please follow the simple steps below.
The Annual Renewal Fee for 12months of SAU VIC membership is $50AU and can be made by bank deposit, cheque or money order.
Haha. It hurts to think that to get my exterior looking like that it will cost more than that car for sale :/
Gee tee arghh time!
Should I buy le genuine type R floor mats for $250-300? very hard to find
Struggling for money yet buys $300 floor mats lol. C'mon brah, I don't even look at my floor mats!
Discounts at garage cafe?!?! this is news to me i've been there a few times and noticed no discount :(
Just got finalised as of today :)
Let's just say I ran into some money. Hehehehe... :)
Dealing is bad mmmkay :P
http://www.skylinesa...__fromsearch__1
$15k for s15's these days? Imports getting cheap now...
LOL! Wut?!
Ashneel's has (at the moment) a S15... Guy goes through cars like no tomorrow.
R33 GTR wheels look decent on any other JDM car except a R33 GTR :laugh:
S15's sure hold their value.
Fireblade is doing it for me.
Need to work out if the 1098 style headlights are on the 600/750cc models...
doubt it. just get the 1000...
Just put good tyres on Rim (see that?); wider will only look better; too wide can be a negative thing for handling.
Scored a bike stand off a mate and went to work on chain/sprockets/wheel today. Used a whole can of degreaser and many paper towels. Sparkling fresh
Gonna hit it with Belring chain wax tomorrow; apparently sticks like shit to a shovel. Hopefully never have a grimy rear or chain fling again.
lol stock is 140 can probably fit 160 but doubt it'll look any fatter/better...
mmm sprocket/chain look new
Guest
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
