My best mate in high school (mates for like 6+ years), called his house once, his mum answered...I say Hi can I speak to Josh please......Yep who's calling?
'It's Michael'
'Just a second'
In the background "Josh phone...It's Michael....Who's Michael?'
'Dez'
'IS HIS NAME MICHAEL?'
Then another time his grandma wouldn't believe my name was Michael until I showed her my license...
How much and where from?
Also have that problem with my first name and people who've known me for years. On the other hand, I have to produce my licence for new people who don't believe my last name.
http://item.mobileweb.ebay.com.au/viewitem?itemId=120944113787&index=1&nav=SEARCH&nid=95945770549
Don't think you can get it locally. So worth it though, not gonna use anything else from now on.
http://item.mobilewe...nid=95945770549
I buy most shit off ebay anyway
I hope this isnt your car... Like a civic needs gold passivated cross drilled slotted rotors... and assuming from the USA markings they dba's?
Slotted rda's are more than plenty and cheaper too :)
Lol inb4 cracked rotors..
Almost as useful as Trd optioned brakes on 86 lol
Indians named Aaron Christopher Francis....It's like Asians named Gary.....or Toby...
Sounds like a serial killers name, is that what you are?
I'm not Indian you f**k.
Could be a serial killer. My dad and one of his brothers used to friends with a serial killer back in Sri Lanka. Obviously didn't know until he was in jail..
Not mine, and they're PasswordJDM ones. Just look awesome. Haha. its not on some standard civic either.
edit, they were like $110 +$80 shipping. only a few $$ more than RDA ones pickup from some places
If I was to do it IDE upgrade to 5 stud and benefit from a larger rotor
1st gen type R brakes (4x100) were the same size as the 2nd gen 5x114.3 (F282 R262). Would not understand why you'd need more on a ~1ton car.
I'd just keep it 4lug and put on type r sized rotors with type r calipers and good pads. spoon 4pots up front if it was a serious track car.
5x114.3 rims in 15-16" are a bitch to find as well.
saving for an engine swap now, not going to spend, srs
Guest
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
