15 bucks I think because there was money for 1st - 3rd. Just playing low money games for practise
Yeah I used to play the $3 or $6 tournaments all the time, used to win a fair few of em so the $ adds up pretty quickly, then I'd play some $11 ones...Kills some time
Yeah with the bigger player tourneys obviously don't win as much but when you do usually a good chance of winning big
anyone good with brakes here
ive removed old pads and the piston has come almost fully out
and i cant get the prick back in
even with the brake line undone and the bleed nipple undone
it still will not force back in
what the?
what the?
Sometimes they spin back in. Have you tried that? To get mine back in they need to be spun for the rear, but different brake setup. Worth a shot
how the fudge does that work?
the piston has a cross pattern on it
I used a g clamp and as you tighten the gclamp is spins the piston. Or is the piston shaped that it can't spin?
If it doesn't work you may have to pull apart the caliper
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
