Nah just doing something for my parents... Was supposed to be a straight forward job, but whoever wired the joint up 25 years ago was a f**king mong, so it turned into a kunt of a job and took way longer than it would have...Got it done in the end though, and at least future jobs should be easier so it was good to start with a bad/hard one in a way..
Definitely not enough room to stand/walk or even crouch...Was crawling around on my stomach trying to stay on the joists...Almost went through the plaster lol
Good fun sabre sawing lying across a few joists, holding myself up with one foot hooking onto a rafter at full stretch lol
Gotta do the same thing in the other bathroom still, just hoping they didn't take the retard route when wiring that one up like the one I did today lol
lol sounds familiar, resting your stomach/knees on the joists isn't very comfy
hate that filthy/dusty insulation they used in older houses
just make sure you're not sore from training the day before otherwise it'll be 10 times more of a mission lol
my foot's gone through plaster couple times got lucky both times it was on top of bulkheads...
we usually try to avoid working on old houses unless it's really worth doing ($$$) or it's for a relative/friend etc
Yeah f**k doing this job if it wasn't for my parents or big $. I don't mind coz I'm getting some domestic experience which I can't get at work, so I'll do any domestic work I can...
Left forearm is f**ked like I ran it along a cheese grater...f**kin sabre saw was shaking the f**k out of me because of the position I had to be in to make the cut, and being hardwood I was cutting for a fkin long time...
And yeah that old insulation is f**ked, would be a lot easier if it was the new shit (which was on top of the old shit lol) as you can just move it around easily..
Definitely need some knee pads for the next one though
haha moving tools with you up there makes it more fun...
careful when lifting your head up alot of houses old or new have nails/screws sticking out of the trusses. dude that used to work with us had half a nail go through his head once. i almost had my fkn eye taken out too
new insulation itchy shit but yea least you can move it
ah yeah, didn't even think of that but did smack my head on a truss lol
Pulled a muscle in my neck/trap on Friday at gym, so was thinking it's gonna be even more of a bitch maneuvering around up there, but I think it loosened it up lol
lol lucky
usually get a sore back afterwards :/
mmmm
http://www.gumtree.com.au/s-ad/appin/motorcycles/triumph-daytona-675/1004413072
guy asks a question about auto -> manual on p's
so a moderator puts in his advice and is completely wrong.
so i input the correct advice. guy says thank you.
moderator has a mini tantrum and locks the thread.
god i love ns lol
http://www.nissansil...howtopic=521776
Edited by Sunkist
JDMST? Pfft...all about the Tony and Birds cruises these days
Will have to organise another one some time down the track
do an SAU wastelander lunch soon.
Your house or Alvin's?
Was good seeing you again today! Hope you don't tell the ato about me today hahaha
Cheers for the sausage sizzle and drink!
I'm not very good with faces so always need a reminder :/
awesome guy
Love you too brah
Guest
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
