Impulsive overspending?
Just need to wait for those in brissie to wire me my monehh
you in the white powder business too?
do HotPot. defnitely good in winter!
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
hotpot
Edited by Sunkist
Dropped car off in the morning to get some tint done.
Was all excite but just got a call saying due to demisters extending too much or something the tint won't stick to the rear window so it can't be tinted? :(. Said he hadn't seen this before :/. Taken pics so I can see when I go and pick her up, but yeah :/
Anyone else encountered this before?
Aaron would need to take off his front bar to get up alvins driveway. Think toby will be find as his is stock height?
I think my car is higher than stock height LOL
Could just do my house, 1/2 way between Aaron's and Alvin's house :P
Not sure, didn't have that problem when I got mine done...
lol then why does the guy want to lower his car? and lol you'd be suprised, my car actually does alright on most shitty driveways.
even better, albino can cook
Saturday night 11 August, I might be doing a small gathering for Bday bbq and drinks.
Could also do a 'smallish' wastelanders food and drinks together on that night as well if there is a few up to it? And if Alvin wants to whip out some delicious food :P I'll pay for the food brah
your going to be wrecked that day from sandown bro
Yeah same day. I was going to do something later for my bday anyway.
Who knows might need a drink to drown my sorrows if something happens that day lol
Lol nothing's gonna happen dude. I might not join in on sandown. Allignment needs a doing and they said I'll need to flare my guards some more(traction tyres) with that and a retune plus cams etcs it's going to be an expensive exercise to only get kicked off for noise.. But will see what happens. Il definitely come watch
wasteland maf**kers, sat night, sept 1st, lagerfields at crown. going to be celebrating my birthday and shit and want you dream boats to be in on the shenanigans. ill have a penthouse booked so...... theres a place to KTFB
You bringing hookers to the penthouse?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
