It's desperate people that have been declined by real banks mostly.
people pay credit with credit and will do anything to get debt collectors off their backs. whilst major lenders are strictly bound by the nccp and will not engage in this type of lending, these small non bank entities somehow manage to fly under the radar. as do many 3rd party collection agencies
a couple of weeks ago i had a customer that had refinanced his homeloan with some small shitty company @ 11.5% ffs
I would love to see the default rate for this.
but seriously who thinks shit I'm that broke now That I will repay 1.5 of it in 2 weeks!!!
fark,
Shit mang, dont!!!!!!!!!!!!
i'll call the butcher tmr and see if he's got wagyu chuck mince. don't grind up the rump caps!
Okay okay...your wagyu is safe...for now. You have 24 hours.
fark,
usually people who have lost their jobs man
BAYSWATER
A & A Industrial Supplies,
17 London Drive,
BAYSWATER. VIC. 3153 sales
Ph: 03 9762 9322
Fax: 03 9762 7532
Email:
[email protected]
awesome. im after the tins though not spray can.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
