Notice given - time to cruise carsales
Didn't you just ask for a pay rise?
Although I do like the look of the R1.. very much so.
$7500
May as well have printed AIDS on the front, that is f**king hideous.
lol dezz and Leigh get R1s
/R1saustralia
Seriously though, love my bike...wouldn't trade it for much, only a top level Duc or a big cruiser if I got sick of sports bikes. You'd be very happy with one, they are just extreme.
another question
Solid mounts: yes or nor(reasons supporting why not)
taking it you talking engine/gearbox mounts?
I moved from the OEM to the nismo "solid" mounts when had the engine out.
Engione def has less movement which I assume is a good thing for the drive train
best point isgearbox moves less so you have much more confidence in where the gear leaver is.
b4 them leave in gear hit boost and it porb moved an inch or so, now just MM.
mates S15 was ever better it was soo sloppy b4 gear leaver would be moving a couple inches when hit boost or lift off, he went same and cleaned up nicely
Yeh so you reccomend.. Is the car uncomfortable to drive with the mounts or as normal? Coz they aren't exactly solid they are just nismo poly urethane right?
Reason I wanted to as I saw it on the dyno and the motor moves a shit load, then Scott was trying tighten the wastegate and as he was pushing against it the whole motor moved. Don't know if fkd or just how it is but I didn't like it. How do you rate 'Megan' stuff? $250 +ship for engine and gearbox mounts, they are pretty much the nismo ones with a different brand stuck onto it
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
