Well so far being a member for a month or two and been to the last 2 months garage cafe meets, SAU vic execs are doing a great job. Not sure how the members section side of things are as i don't have access yet....
Just curious, who is this Ash guy? I still want my members access lol
Member section is dead. Nothing in there. All chat happens in this thread. Nothing to lose sleep over.
lol, i didn't mean it in a way to imply that you said anything negative about the vic commitee. I clearly understood what you were saying, chill brah! :spank:
Just wanted to voice my opinion on my experience so far with the vic commitee. :nyaanyaa:
Deep down Aaron is a big softie
Don't take to heart much what he says :P
lol f**k Precinct, line all the way to Punt Rd after 9pm and idiot bouncers who let in people with shitty runners on but not Timberlands/Colorados. Take your mates up Swan St for better pubs/hangouts.
yeah well I looked at all the modern cars.
86
GTI
focus XR6
none of them worked for me
so I thought I might spend a little less and get a fun car
so looking at S15 or 34 GTT
but damn, how cheap have 33R's got, so i'm thinking for a low KM daily why the F not have something fun!
so atm it a 33R or a evo6 TME
I had exactly the same thoughts as you. I was tossing up between the 86/BRZ and the GTI. But fairly certain I'll go for an 86/BRZ later next year. An R34 GT-T or S15 crossed my mind but they're a bit old and the fuel consumption of the R34 would be too crap for a daily again.
I'm not so worried wabout fuel usage as It will get low km
We will lease a nice daily something Like a tigran or similar that will be the main car and do most of the km. then a 2nd car for me for when I go in the office or run errands. so will do 3-4000 km a year.
So might as well have some fun.
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
