just thought it's worth a mention...
a while back the state club exec's had mod access and a few flogs abused the privilege and acted like a bunch of mad82's, so Christian put down a flat ban on it.
Ash is not the one that makes this call, so lets not be pulling his name into it.
was it the right choice? no... but that's how it is unfortunately. At the end of the day it's christian's ship and he's gonna sail it how he wants.
I couldn't even get mod access when i started as president... which is just fkn ridiculous as you get pm's from everybody wanting shit moderated when they know you are prez. (i feel sorry for richo)
Went to Toyota dealer. Had a grey auto gt on display. Nice looking car. Dealer says 18month wait if order placed O_o
Feels like this got lost in between the whinging and fake rims
Who finds 18months acceptable? It's not that great to be waiting 18 months for IMO :/
Go to another dealer
It was about a 12month wait via fleet
So buying it private should be shorter 6-12 months
And yet mad082 is still a mod...
I think you have to be an administrator to be able to give members' forum access to people, Ham.
Sounds like SAU Vic has started selling 86s haaaaah!
Yo look to the side when you're driving next time. Trying to wave to you on the Eastern last night, you prolly thought I was a cop in a white VE wagon lol.
By R34 i mean GTR 34.
Everything else is reasonably priced though. 32 GTR ~ $15K 33 GTR ~ $20K.
hmmm i suppose ur right seeing as min u b paying 40K for a decent GTR34......
dudes i am sahhhhhhhhhhhhhh BORED!!!!
i hate sundays
-________-
Continuing with the theme of blacking out my R1, I ordered these adjustable Yoshis to replace the factory silver rear sets. $450...this bike is gonna be my new money pit!
Now looking for brake/clutch levers. Thinking Pazzo, but I don't really like their machined/jewelled look on the surface. Rather something smoother looking. Black lever with gold adjuster would be good for my "black with gold touches" theme, though.
Guest
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
