You sure they're not CBRs they do look similar...
Saw an undercover motorbike pulling someone over :/ wasn't aware of their existence....
I saw that too the other day.
but they're bikes looks somewhat "Travel" like, right?
Just spent another 2.5 hours in Rimon's territory aka roof space. I love that shit now.
Lol did some roof work myself too today was in a new house though and very roomy :P
I see ALOT of spider webs in roofs even in new houses but never see the actual spider. 9/10 it's them harmless long legged spiders so meh
Come past mine afterwards, I'll be home :)
okay darling, spoke to the guy on the phone and agreed / he advised not to go for a balls to the wall tune and turning the wick all the way up hopefully a mild 350ish rwkw on his dyno (anything over i'll take as a bonus), still huge power some tuners go really aggressive with hem though but I won't just yet while it's still new..
lol the no lag thing is weird, compared to a laggy turbo car (ie my old GTR) that sudden rush of power I do miss.. but pulling skids in any gear is also fun :P and don't need to rev the crap out of it to go half quick. A v8 twin turbo would be my preferred balance :D
Aaron, you can never have enough power thought you knew this? :P
nah definitely 675's, they've got the badging on the fairings...
Yeah heaps of that around up there, but didn't see anything moving.. I've gotta do an exhaust fan or 2 at my place still....More room up there from what I've seen, but also had a rodent problem a while ago so not looking forward to getting up there...Especially when one of the fans needs to be installed about 2 meters from where I used to hear them the most...Should be interesting, hopefully they've all died and decomposed by now, and hopefully the smell is gone. Haven't heard them for ages so I'm confident they're all dead/moved out, but still likely to find some remains...
Hope you got some new tyres lined up...
Don't need new tyres when your fat ass weighs 1800kg.
Just pumped mine up...265/35 @ 33psi lol. 40psi makes such a huge difference to the comfort and handling.
Bunnings is the worst store to go and buy something specific; end up there for 2 hours browsing at other shit.
to the 86 dirvers, is the "awesome driving experience" simply because the thing is so underpowered that you just leave your foot on the floor and turn the wheel?
srs question...
my ksev was like that and to have fun you had to treat the clutch like rodney king
lol thats probably it. well balanced, low centre of gravity, rwd & foot flat in the corner. Probably feels a lot safer than a 350kw ford falcon doing the same thing haha
lol
where you putting em in bathroom/toilet? just run the wire from the light with a tongue/snake and save yourself getting up there
unless you want your lights/fans controlled seperately then different story...
lol
Yeah bathrooms, seperate switches for heat lamps/light/fan all in the one unit...
Don't know how you'd get a tongue from the light to the switch without getting up there though? please explain.
Whatever you're about to explain might work on a house that wasn't wired up by f**king retards, which this place was...Made a simple job a headf**k and a half
Don't be hating on the falcon :(, 350kw + pedders = leave a 86 for dead through the hills :P not as bad as people think in the dry at least
Put my engine in the 86!
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
