Yeah bathrooms, seperate switches for heat lamps/light/fan all in the one unit...
Don't know how you'd get a tongue from the light to the switch without getting up there though? please explain.
Whatever you're about to explain might work on a house that wasn't wired up by f**king retards, which this place was...Made a simple job a headf**k and a half
i meant loop it with the light holder but you've got that 3 in 1 shiz still same thing though
do you want the e/fan and the unit fan to turn on/off together or the e/fan to have a seperate switch?
Nah I'm gonna go buy my V6 Live axle mustang tha'll rape a gt86 Straight line and on a track...and is cheaper..
seriously have you driven a USA stang?
I assumed it would handle like my xr6 ute, both 4L rwd live axle
damn was I surprised, the mustang is the worst car I have ever driven.
Think we're on a different page...Not sure what you mean by exhaust fan and unit fan....As far as I'm aware it's just got an exhaust fan... The one we installed in the main bathroom has 4 heatlamps that operate in groups of 2 with a switch per pair, a fan switch for the exhaust and a switch for the light
The ensuite one is the half size with 2 heat lamps on 1 switch, fan on another and light on another..
ah so you already have the exhaust fan installed and wanna put in the 3 in 1 unit?
thought was the other way round and you just wanted to add an extra exhaust fan...
No no...Neither bathroom had any exhaust fan at all....My dad wanted the heat lamps as well as exhaust fans in both, so my brother bought the martec units which had both in the one...
The fans themselves aren't as powerful as they need to be imo, so I might get 2 seperate ones and run the fan wires to those instead of to the 3 in 1 units....They'll still have the heat lamps and light in the main unit, but the stand alone exhaust fans will do a better job than the fan in the 3 in 1 can do... And at least I know for sure that it'll be a simple job, just loop it from the SDI running to the fan in the roof and hook it up to the stand alone exhaust fan so it'll still be operating off the same fan switch as the 3 in 1 was.
/electriciansaustralia
Wastland gurus, think I can get some frush look with spacers and no guard work? Not after huge aggressive stance, but just something that isn't as sunken as it currently is :S
Edited by kaitoukid
at minimum you'll need a guard roll.
maybe some 8mm spacers.. should sit nicely. I dont know why you'd bother though, its practical right now.. i'd leave it.
ah i see lol
well yeah that's what i was saying before then just loop it at the 3 in 1 unit and have both stand alone e/fan and the unit e/fan work together off the same switch. that's what we usually do anyway for people that want the 3 in 1 coz like you said the e/fan in the 3 in 1 unit is useless
8mm spacers and guard roll then, you think bro? haha so over practical (i'm sure there may come a time when i rue these words :P), you haven't seen the ride height! the box you can see in the reflection currently has my coilovers sitting in it! need free time and some tools so i can install them!
edit:
as you can see, dat gap! D:
Edited by kaitoukid
yeh im not a fan of slip on spacers though.. less wheel nut thread is dangerous.
i'de put the coilovers in, get some camber arms and get the thing aligned. if your still not happy then perhaps some bolt on spacers... even if you were to put extended lugs on there they are still weaker as the nut is further away still, more distance there is, a higher a chance you have of snapping studs..unless you go bolt ons, I wouldnt consider anything else.
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
