mine is fine.. maybe you broke something?
Nah nothing. Everything went straight in according to Scott car drives fine. Just idle lol.
They arent nismo they are megan ones. But essentially the same. Maybe I shouldve just gone nismo
Kinda off topic, kinda not....I would like to If I may talk clutches.....
what are ppl using thesedays? With what power, usage of vehicle and longevity?
I would like some recommendations please....but not of extreme....as it appears my years of support of them and my purchase of many(probably around 6 id recon) clutches still doesnt deem me important enough of a response from them....so they can shove it.....(this is the 2nd time I"ve contacted them with null response....grrrrr end rant)
Does anyone have the hookups for clutches at a better price? Its been so long since I've been in the trade now...wahhh retail hurts..
Want me to bump the idle up a bit? Perhaps its harmonics at that idle speed?
I heard something banging underneath the front too when you took off, perhaps the cooler pipe? Could you be feeling that through the wheel somehow?
I'm running an exedy HD organic, not huge power 180-190 rwkw but lasted me near on 3 years of track use so pretty happy with that.
Haha enjoy.
What do you reckon of the new marv creations? Popping candy and jelly bits.
Popping candy tasted good, though I'm guessing it's targeted at kids as pop rocks usually are. The jelly one got stuck in my teeth hard lol, ruined a pod block of chocolate for me...but my mate loved it so meh. I love mousse too, but can't beat the classics sometimes. Do you guys do Top Deck in bar form?
NPC
/topic
Cooler pipe could be right to some extent seeing as the engine has moved a little.. But I doubt that much. Drive it tonight when I come past
At the moment, I have the Nissan GTR clutch but Racepace will be strengthening it to handle 300+ rwkW.
Or go an Exedy or Nismo Coppermix.
On The Run Motorsport could help you out.
A friend of mine ordered off RHD Japan's website, take a look.
Did you pop your motor? What's planned for it?
I'm using the Nismo Super Coppermix twin plate. Great clutch which can handle a heap of power (400+kw) and it feels like your using a standard clutch.
spoke to jamie at garage cafe one of his pistons was knocking or something, he's getting it rebuilt (forgies) with -5s or similar
Think he wanted -9's. Were trying to convince him to go -5's to make use of his built engine, we'll see if he will succumb to the powah!
But nah -9's great for the street!
Hey Toby accounting question -
Is there a downside to buying a car outright (cash) I mean I know you won't claim interest etc but that's fine cos you don't have to pay it in the first place.
So im guessing the only negative is that you don't have the leverege that keeping the cash at your disposal provides
Does that make sense?
Edited by alr33x
Guest
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
