Yeah, lots of good reviews. 1.2k, can't complain. If i bought the specific ones for my civic (fork), it'd be 1.1k. But I'm running integra type r stuffs underneaths, so have to pay for that type R tax :[
That's the price you pay Honda fanboi lol
All coilovers look the same in the end anyway :P
Must admit loving my pedders coilovers so far
What do pedders charge for coils roughly?
Seems legit
1750, but fords have separate springs from shock on rear so dunno if that makes it cost more or what ever
pretty funny how my stock springs only saw like ~2000kms lol but this completely transformed the car to something more sporty feeling with a luxury side as well way more difference compared to getting them in my GTR
Just want an intercooler, exhaust, brembos and wider rims now! modding bug never stops..
like this (to make sense of it) not sure what brand this is though:
Nah price won't affect the rear shocks being seperate, vdubs have seperate rears and price is same as normal coils
also, LOL
HAHAHA
Did you pop your motor? What's planned for it?
Yeah, from what Racepace figured out, piston 5 had a cracked head, making a loud knocking noise and loss of compression.
Wanted a standard rebuild, but Racepace justified how a forged will benefit in the long run and I totally understand.
spoke to jamie at garage cafe one of his pistons was knocking or something, he's getting it rebuilt (forgies) with -5s or similar
Yep, but using my stock (rebuilt steel internal) turbos for now.
Till I speak further to Chris about what he thinks.
From memory, he prefers -7's.
Jaime did I see u at wtac?
Hey Alex!
Nah, don't think so man, I didn't go to WTAC.
How was it? I saw some pics and they look quite good.
Think he wanted -9's. Were trying to convince him to go -5's to make use of his built engine, we'll see if he will succumb to the powah!
But nah -9's great for the street!
:D
If I had a HKS V-Cam or a stroked 2.8lt RB, then -5's would be an option.
But yes, for street use, -7's or -9's.
Guest
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
