You never win, when you are in le position there will always be more expensive things to get.
My r32 was better off when I was a student on casual wages. Now its all about budgeting & being serious with money :(
The sad reality :(
Yeah no doubt commitments and responsibilities just continue to grow! I guess sometimes at the end of the day, you just have to bite the bullet and go for what you want and deal with the rest! :P
but telstra you pay $$ for the good connection. vodafail serves me mostly; although their dodgy reception can be a pain at times, but generally not that many dramas for me thus far
as I presumed, I would also because brunette > blonde
that is true
Telstra or Optus.... Never seem to get reception with Optus atm but could be that phones f**ked
Either way get to finally upgrade, S3 here I come :D
optus seems to always run out of reception when you need it most...
also upgrading next month to an S3 good timing since my phone got smashed yesterday
telstra...
havent been to one place without reception yet, even elevators i seem to have a perfectly clear convo
Yeah that's what I want, reception.
Optus has a tower 5mins away from my house, and I still don't get reception some days :S
not really both Optus and Telstra have $80 plans, and most people would think Optus cheaper but there plan comes in at $2016 over 24months and Telstra is at $1920
Also Telstra has free to talk from 7pm to 7am during weekdays and all day weekends where as Optus don't on theirs. The only thing Optus give you is $50 more calls (makes no difference with free talk, and .5gb extra data which I never use all mine cause I'm usually on wifi anyway)
that is true
Yeah that's what I hate most, especially because phone is used for work calls too
Telstra its no contest I had Optus and it just failed epically in same spots everytime - pay $30 more for Telstra but for my kind of work it's well and truly worth it!
Underground car parks full reception love it.
Oh yeah? I haven't really looked at phone/contracts recently (mine only ends next Jan, or even with early exit deal of some sort still a few months away) - but just thought as a general rule telstra you do pay more for less (in terms of plans/handsets/random additions - but you do get more with mad reception as everyone here is saying haha). Will have to keep an open mind and check out telstra when contract is up then this time maybe hmm :P
Guest
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
