Just did a online quote for 32 GTR, and it's $500-800 a year cheaper than R33.
A car without airbags and slighty weaker chassis is cheaper to insure, lolwut?
what!? really who with? never heard of it going up with any claims..did you modify your policy? add mods?
Nope. Didn't add anything. They are using the hail damage claims as a "reason" to up premiums to recoupe the costs.
Someone also called JCI and was told of using hailstorms that happened on last xmas as a excuse to jack up the premiums.
Pretty pathetic if you ask me.
Just go Shannons!
I was with Just Cars but this year they reduced my agreed value and up the premium.
Shannons gave me a cheaper premium and kept my higher agreed value from what Just Cars gave me last year.
Shannons only managed to shave $30 off a year, hardly worth parking it in garage every night for.
RACV, with $2k excess, they want $972 for 32 GTR and $1397 for R33 GTR...
But your excess is higher...
So in a sense it evens itself out.
But if RACV is doing you good so far then just stick with that.
Well, not that keen on paying $2k excess should the time comes to when I have to make an claim. And RACV doesn't list their 'market' value on the website so I looked through Redbook, I felt it isn't worth paying $2k excess for $12k 32 GTR. Plus I'm unsure how flexible RACV are with modifications.
Ah ok, I see.
Still, give Just Cars and Shannons and negotiate to an agreement of what suites both you and them best.
Old plastic clove clip things nissan seem to love are so annoying! Managed to only break half of 1 though... Taking off the plastic wheel arch thingy took a proper awhile trying not to break those brittle bastards lol. Think years of outside work hardened them :S
Guest
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
