i like the clean look of the 9's too..not much of a fan of all the holes and vents all over the 8's either, but keep it standard, just a tune. maaaaann
Haha those are 8s with nose chops :P they take the middle part of the bar off and makes it look heaps better, sort of like a 9
see original 8 bar that weird shit in middle makes it look like a magna
Yeah nose chop looks the goods on the 8s. I'd probably go the 9 (or maybe even 06 Sti) if I have the funds, but unless find a steal or prices come down a lot, think it'll probably be out of my price range unfortunately :P. 8 + money for mods looks tempting as of now, but only time will tell. Ahhh can't wait!
An e60 will be a better option in a few years e39s are all fkd already massive kms great car but won't be worth it in a few years
Love the sound of the e60 V10. Sounds baws
I'd say stuff cars set up your future I pissed so much $$$ away on cars could have been in a way better position now but eh hindsight
Says the richest guy on Wastelands lol
Surreeee......
What's the catch? 01kms? Seems suss lol
I'm poor Toby I'll be flipping burgers soon! Wouldn't mind moving up here though broadbeach is awesome
Drop in at the Greek Cafe, Shop 6 Phoenician, Broadbeach.
Client owns the premises, maybe they give you a discount yo!
I'll drop your name Toby see how I go! Think it's opposite where im staying
Nah not my name, I only know the land owner not the business owner.
Try dropping the name Andrew Guild, say your best mates
Going to get an Evo Grant?
To be honest, I don't know what I want...
Last night I actually thought about getting a herpes (a Scooby not a sex disease!), until Leigh jumped on FB and tried to be a Ford salesman and tried to talk me into getting a XR6T...
Agree xr6 t or evo would keep you away from popo if you stay away from cosmetic styled mods. Hence why I'm over the 200
Popo isn't the reason, it's insurance. Although, both Evo and Scoob are $2k a year whereas XR6T is $1.2k a year along with BF F6, VE Commo SS (HSV's are $3k plus).
Never had a problem with police with all the Skylines I've had, I guess I'm lucky...
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
