Aaron 3rd party fire an theft for sure why pay a quarter of your cars value in insurance?
For what it's worth imports suck my is250 costs $1.4k I think it is full comp $48k value
Edited by alr33x
http://www.mismotorsport.com/home/
seems shannons do not do it anymore, oh well.
Well there you go, I apologise Grant.
I'd hate to hear what the premiums and conditions are like...
will do something else next round. hotpot gets boring really quickly..
and. boost bars.. ugh, sick of boost bars already? when i find the time, i'll individually wrap them in cling wrap....
and i'll have to pm you tonight too. about vac work.
haha cling wrap your cat dude. im still waiting.
yeh i think i'll just stick it out for the next four months until the premiums done, then drop down to third party. no point. with the turbo they probably wouldnt cover my side of it anyway. plus if someone taps me im still covered.
I reckon the company is aimed for proper race team with blue chip sponsor rather than club level motorsport guys like el presidente and Martin.
Premiums will cost more than somebody's house and conditions are stricter than Queens guards I'd imagine
one of my mates has an evo and rekons once you go GTR you cant go back...
see how that goes grant :P
for the people whos numbers i dont have, lagerfields @ crown for my 20th this saturday night :) though, alex better not get in my face, or ill drop that mother f**ker.
EVO vs GTR = 2 different types of cars.
One has a larger displacement with 2 extra cylinders and 1 extra turbo.
so i have a dillema.
insurance renewal is coming up.
for some f**king unknown reason my premium is still going to be
Justcars
$2700
with an agreed value of $10,000.00 :S
with excess of $600.
can only imagine shannons will be more, once the current cover ends.
or I could go thirds party fire and theft for $400 PA.
GRANT - im not sure, I will need to call them back so I will ask... but I dont think any insurance company does.
Are you driving it everyday?
Shannons, Limited Use.
very true the response and handling in my brothers evo6 shits on my gtrs
i actually might have to give it a miss, or leave early.
PI the next day have to be at PI at like 7 or some gay hour.
7 thats my first smoko break..whoss the sissy now biaaatch
PICS!!!!
picture doesn't do much justice.
might not look low but i cant make it over any speed humps without scraping around my area, my driveway i had a bitch of a time getting up.. might need to raise it a little or ill find myself tearing the lip off =/
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
