VII.9 :yes:
The VII is a bit unloved, as the body styling is plain when compared to the VI and VIII.
VII are cheap, why would you bother with a VI with flogged bushes and gearbox.
inb4 Richo buys one for Time Attack
According to Wiki:
R32 GTR - 1,430kg
R33 GTR - 1,550kg
R34 GTR - ?
Evo 6 - 1,260–1,360 kg
Evo 7 - 1,320–1,400 kg
Evo 8 - 1,320–1,410 kg
Evo 9 - 1,310–1,490 kg
Add 18" wheels/tyres, exhausts, bigger brakes (a common GTR upgrade where EVO doesn't) and so on and it can certainly get higher :)
I suspect a R33 is heavier than 1550 to start off with. My GTS-R was 1400kg without me in it as i weighed it, and the GTR feels a LOT heavier than 150kg more. I remember driving Snowys R34 years back and it felt like at least 250-300kgs packed into it as it was similar from driving a EVO6 to a R33 GTR feels about the same in terms of difference.
Plus half the time the figures are not 100% accurate from a manufacturer as they dont say if its kerb weight (full fluids) or not.
A 6 and a 33R similar weight? No chance .. ive driven both and the 6 feels much lighter, even though the 33 R ha more power.
Maybe a 7 might be nearing the weight of a 33r but I doubt it
Seems about right
I can confirm this for you, my GTR is a 1999 R34, i have coilovers and a exhaust on it with a set of NUR spec NTo3+M rims, and i had to weigh it for blue slip, it came it at 1640KG with a 3/4 tank of fuel.
With next to no fuel,...
Eastern Ck weigh station (if accurate)...
V-Spec N1 = 1528Kg
Tony, nah cos no mention of N1 turbs, PFC and I don't see Brembos from the pics.
Different coilovers and 30,000-ish km has 'disappeared' there's paint fade on the roof that I don't recall seeing when its in my ownership.
Lol Aaron what you smoking brah
Don't think anyone said the 6 and the 33R were similar weight :P
what it sounds like? lol i've read it three times and sounds the same.. maybe my mind is f**ked today
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
