GTRs are good and all but too old to buy now IMO, even when I spoke to Vu about his 34 he said he had to replace some major parts that were rusted the same as my R33 :\
Id go for a mid 2000s evo instead if possible (7-8-9) but don't really like the interior that much
what it sounds like? lol i've read it three times and sounds the same.. maybe my mind is f**ked today
Lol your brain is fried.
I read it as:
The difference between driving his GTS-R and an R34 GTR weight difference was similar to the differences between an EVO and R33 GTR being about 250kg's
I read it as:
Oh brains fried.
inb4 Richo buys one for Time Attack
lol, don't event tempt me more than I am. Such an easy car to go fast in, extracting that little extra is super hard though.
8mr ftw
errrr, yep there goes the value for money. 8MR is like buying a NUR, well not a far as NUR but similar. It's the pimp spec, but for the same money you can make a much better VIII or IX.
VII is what...17K buy price (22K asking) and a VIII MR is 30K buy price. I'd buy a IX over an VIII MR any day, they are pretty much the same price and the IX is far superior engine wise.
One of the OTR VIII is up for sale atm, bargain for what it is.
Also Dan's East Beat GTT is for sale again in the ACT.
Yeh I'm considering 6 or 7.. Hopefully this guy buys my car
7>6 any day... 6 are too outdated
Fair point. Apparently the VII have weaker rods though, although I prefer the VII To the other girly ones. Not gonna do much if I get one though so come at me weak rods
I've heard of guys running upt o 260kw or more in 7s as long as you don't have a huge torque curve it'll last
It's actually the quick torque from responsive power setups that generally kill the rods
however to rebuild forged 2.4litre engine is cheaper than rebuilding a forged 2litre
5 was the best looking Evo. Or should I say, the least ugly.
I'm a HUGE 5 fan, but they are way to outdated now
plus to mod them they cost more than the newer models
Add 18" wheels/tyres, exhausts, bigger brakes (a common GTR upgrade where EVO doesn't) and so on and it can certainly get higher :)
I suspect a R33 is heavier than 1550 to start off with. My GTS-R was 1400kg without me in it as i weighed it, and the GTR feels a LOT heavier than 150kg more. I remember driving Snowys R34 years back and it felt like at least 250-300kgs packed into it as it was similar from driving a EVO6 to a R33 GTR feels about the same in terms of difference.
Plus half the time the figures are not 100% accurate from a manufacturer as they dont say if its kerb weight (full fluids) or not.
EVO's are on par easily with GTR's, well the ct9a anyway
Few of the evolutionoz.net guys have weighed them and they come up to about 1450kg with half tank of full (about 29litres LOL)
A 6 and a 33R similar weight? No chance .. ive driven both and the 6 feels much lighter, even though the 33 R ha more power.
Maybe a 7 might be nearing the weight of a 33r but I doubt it
different cars, the gtr being longer is less 'nimble' so the evo with feel lighter anyway
they heavy cars, the only really light ones are the RS's
Guest
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
